Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-07-2011, 03:12 PM
shakeel.salam shakeel.salam is offline
Caprice SS 2000 Model V8 and 5.7 Ltrs engine
Dear forum members.
I am facing Problem with Caprice SS 2000 model .
Engine Heating when AC is turned on. with out AC the temperature is up to half as soon as AC is turned on temperature gradually raises.
I have checked Fans.coolent,new radiator and new radiator is flushed ones. still there is a problem
when checked with mechanic he says its a common problem . and there is no solution . its really painful in hot summer of 50°C.
Please give your valuable feed back.
Regards
shakeel
Old 06-07-2011, 09:54 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Caprice SS 2000 Model V8 and 5.7 Ltrs engine
Originally Posted by shakeel.salam View Post
Dear forum members.
Regards
shakeel
Check to see if the radiator in your car is up to the task for your area.
To be honest, you might get a quicker response with this car if you ask in the Holden / Commodore section as this is what this car is.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-08-2011, 08:37 PM
j cAT j cAT is offline
Dear forum members.
Regards
shakeel
with any coolant system the use of distilled water is recomended to prevent a mineral/scale type of build up...
I would drain the engine using the knock sensors holes if this is the LT1 engine or whatever needs to be removed opened to do this ..then add an acid coolant flush to completely cleanup the built up deposits..then after flushing and compltely draining add 50 % coolant with 50% distilled water...do not use non distilled water..also do not mix coolant types..
the system/thermostat/an pressure should be checked ...
make sure you have the correct thermostat part..you may find this engine uses a specific thermostat...
with temps above 100deg f/50deg c you must have no leaks...make sure also no air in the system..
'92 350 5.7 ltr- cracked block or head gasket? relic000 Express | G Van 5 06-07-2010 09:48 AM
please help 5.7 liter hawk713 Caprice 1 04-22-2010 08:05 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
difference between 2000 5.3 liter and 1997 5.7 liter engine The Ladies Man C/K 14 08-18-2005 07:00 PM
