Old 06-07-2011, 01:22 PM
eyckles's Avatar
eyckles eyckles is offline
Mr. Topcoat over Tamiya X22
Hi guys,
I have a question. Can i spray mr. Topcoat over tamiya X22 acrylics? Has anybody some experience with this.
Lesley
Old 06-07-2011, 05:02 PM
stevenoble's Avatar
Re: Mr. Topcoat over Tamiya X22
You can use it over X22, just be careful.. Why are you using clear over clear..?? Tamiya X22 is not a very good clear. It takes forever to dry and it marks really easily when handled. If you haven't already used it, don't, just go straight to the Mr Top Coat instead would be my advice and skip the X22 altogether...
Steve Noble
Old 06-07-2011, 05:35 PM
eyckles's Avatar
Hi Steve,
Thanks for the quick reply. I already put X22 on the porsche a couple of days ago. It's already dry, but the result is not so great. I had better results with X22 before on my Ducati and it looked great. I have heard if you decant Mr. Topcoat and thin it with Tamiya acrylics thinner it can be use thru the airbrush, but i'm not sure. I wouldn't spray it directly from the can, because of the gasses. Also is it possible to spray 1k Or 2k from zero paints over this?
Lesley
Old 06-07-2011, 09:31 PM
935k3's Avatar
935k3 935k3 is offline
If the paint under the X-22 is anything other than a water based Acrylic(like Tamiya Acrylics)You can use Ammonia to safely strip off the X-22 without affecting the underlying paint.
Old 06-08-2011, 03:47 AM
Tibi Keke's Avatar
Tibi Keke Tibi Keke is offline
I have used in the past Tamiya X 22 as base for decals on my Airplane models and sprayed after with Gunze's B 502 Topcoat semi gloss. The models are now 3 years old, everything is the same, no crack now nothing! So you could use this clear over X 22 without any problem. Mr. Top Coat is a bit more glossy than X 22. If you spray them with airbrush, you can mix them both with Mr. Color Thinner. Works fine and hardens better! For polishing you will need to wait some days, Mr. Toapcoat hardens like hell imediatly but will melt under your fingers. So don't rush and let them dry completly!
PS: wear some latexhand gloves!
Tibi
Old 06-08-2011, 06:01 AM
stevenoble's Avatar
Lesley
Not entirely sure about that. Seems you can spray the 2K over most things and it's not so bad, but not sure how strong the 1K is. If in doubt I wouldn't mix different clears, stick to the same brand of clear and usually they will work together with no problems..
Steve Noble
Quicker way to cure Tamiya X22 Acrylic Clear? mickbench Car Modeling 6 05-18-2006 09:03 AM
Tamiya TS-13 over Tamiya XF-1? Tikiman Car Modeling 9 11-11-2004 06:02 PM
Tamiya clear spray over Tamiya Matt spray? Tikiman Car Modeling 5 08-31-2004 03:54 PM
Alclad II over Tamiya Primer and Tamiya Synthetic Laquer? Deejay27 Car Modeling 11 04-23-2003 05:59 PM
Automotive Lacquer over Mr. Color or Tamiya? djmr2 Car Modeling 0 02-15-2003 10:08 PM
