Old 06-07-2011, 12:45 PM
plodder's Avatar
plodder plodder is offline
2000 Chrysler Voyager 3.3 Fuel Pump replacement
HEllo, I need to know if I can change the fuel pump on my 2000 voyager without dropping the tank.
Is there an access panel inside the vehicle. Can the fuel pump be removed with enough clearance?
I have replaced a fuel pump before in a jeep. is this simple enough for me to do on my own? Are there any potential complications or dangers I need to know about before I try and do this on my own.
Also does anyone have or know where I can get instructions or pictures for fuel pump replacement on this vehicle? Also can you recommend a brand of fuel pump or warn me which brands to stay away from?
Is there any other reason the fuel pump would not be working besides being bad....like a fuel module or a fuse or something?
Hope is the destination that we seek.
Love is the road that leads to hope.
Courage is the motor that drives us.
We travel out of darkness into faith.
Book Of Counted Sarrows
Old 06-07-2011, 06:56 PM
autotech234 autotech234 is offline
Re: 2000 Chrysler Voyager 3.3 Fuel Pump replacement
Here are the steps as out lined in in manual.
FUEL PUMP MODULE
WARNING: RELEASE FUEL SYSTEM PRESSURE BEFORE SERVICING FUEL SYSTEM COMPONENTS. SERVICE VEHICLES IN WELL VENTILATED AREAS AND AVOID IGNITION SOURCES. NEVER SMOKE WHILE SERVICING THE VEHICLE.
WARNING: THE FUEL RESERVOIR OF THE FUEL PUMP MODULE DOES NOT EMPTY OUT WHEN THE TANK IS DRAINED. THE FUEL IN THE RESERVOIR WILL SPILL OUT WHEN THE MODULE IS REMOVED.
REMOVAL
1. Remove the fuel filler cap.
2. Insert a siphon hose into the fuel filler tube and drain the fuel into an approved gasoline holding tank until the fuel level in the tank is at or below 1/4 full.
3. Remove the cover from the Power Distribution Center (PDC).
4. Remove the fuel pump relay from the PDC.
5. Start the vehicle and run it until it runs out of fuel then crank the engine for an additional 10 seconds. Turn the key to the OFF position.
6. Install the fuel pump relay and PDC cover.
7. With the ignition key in the OFF position, disconnect the negative battery cable. NOTE: To enhance customer satisfaction, remember to record all radio settings before disconnecting the battery and to reset all electronic memory (clock, radio settings, etc.) when you have completed the service procedure.
8. Raise the vehicle on an appropriate hoist.
9. Support the fuel tank using a transmission jack.
10. Remove the two (2) inboard fuel tank strap bolts.
11. Lower the inboard side of the fuel tank about 3" to allow access to the fuel pump module.
12. Using a shop rag, clean any dirt and debris from around the fuel pump module area.
13. Slide the fuel pump module electrical connector lock to the unlocked position . Push down on the connector retainer and then pull the connector from the module .
14. Disconnect both fuel line quick connects from the fuel pump module .
15. Clean any excess gasoline and/or dirt from the fuel pump module flange.
16. Using Miller Tool # 8269, remove the lock nut .
17. Clean any excess gasoline and/or dirt from the fuel pump module flange.
18. Slightly raise the fuel pump module and then remove and discard the fuel pump module seal. NOTE: It is not necessary to remove the fuel pump module from the fuel tank to remove or install the fuel pump module seal.
INSTALLATION
1. Check the outer diameter of the fuel tank pump module mounting boss threads using the provided Go/No-Go gauge (Miller Tool # 8585) .
o If the Go/No-Go gauge fits over the threads (Go) and can be moved to the tank surface, a NEW lock nut MUST be installed.
o If the Go/No-Go gauge does NOT fit over the threads (No-Go), the ORIGINAL lock nut must be re-installed.
IMPORTANT: The Go/No-Go gauge must easily fit over the mounting boss threads. Do NOT use excessive force when attempting to install the gauge.
2. Install the new or original lock nut as determined above. Make sure that the locating tab on the fuel pump module is aligned with the notch in the fuel tank. IMPORTANT: Do NOT install the new lock nut seal at this time. NOTE: The new lock nut I.D. is smaller than the old lock nut and therefore will have a much tighter fit to the fuel tank. Be careful not to cross-thread the lock nut.
3. Using Miller Special Tool # 8269, tighten the fuel pump module lock nut to 20 ft. lbs. (27 Nm) . IMPORTANT: The lock nut MUST be tightened using Miller Special Tool # 8269. Do not over-tighten the lock nut. To ensure a correct torque measurement, the torque wrench must be installed in line with the special tool handle.
4. With a paint marker or similar tool, mark the top of the fuel pump module and the lock nut to indicate the location of the arrow on the lock nut after the lock nut has been tightened without having the seal installed .
5. Using Miller Tool # 8269, remove the lock nut.
6. Slightly raise the fuel pump module and carefully install the NEW fuel pump module seal (Fig. 15B). Use care to not stretch the new seal when installing it over the module. CAUTION:Make sure that the new seal is fully seated on the fuel pump module sealing surface.
7. Install the new or original lock nut as determined in Step 1. Make sure that the locating tab on the fuel pump module is aligned with the notch in the fuel tank (Fig. 15B).
8. Using Miller Special Tool # 8269, tighten the lock nut to 35 ft. lbs. (47.5 Nm ) . IMPORTANT: The lock nut MUST be tightened using Miller Special Tool # 8269. Do not over-tighten the lock nut. To ensure a correct torque measurement, the torque wrench must be installed in line with the special tool handle.
9. Check the position of the arrow on the lock nut relative to the mark made on the fuel pump module in Step 4.
o If the lock nut has been tightened such that the arrow is at or beyond the mark on the fuel pump module, continue with Step 10.
o If the lock nut has been tightened such that the arrow has not reached the mark on the fuel pump module, tighten the lock nut further until the arrow is aligned with the mark.
10. Connect both fuel lines to the fuel pump module . Push the connectors on to the nipples until they are seated and then pull back and push on again to assure that the connectors are secure. NOTE: Wipe any excess fuel from the fuel pump module.
11. Connect the fuel pump module electrical connector. Be sure to slide the retainer into the locked position .
12. Raise the fuel tank into position and install the inboard fuel tank strap bolts. Torque the strap bolts to 40 ft. lbs. (54 Nm) .
13. Remove the tank support and lower the vehicle.
14. Refill the fuel tank.
15. Connect the negative battery cable.
16. Start the engine and check for any fuel leaks.
The Following User Says Thank You to autotech234 For This Useful Post:
plodder (06-16-2011)
2000 grand prix stalls jay44 Grand Prix 51 03-01-2013 08:10 PM
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
4.3 ZR2 Fuel Pump Replacement ??'s mx6rrr Problem Diagnosis 5 02-26-2010 04:10 PM
bmw 325 fuel-pump testing and replacing dieter 3 Series 2 08-12-2009 02:46 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
