Old 06-06-2011, 05:08 PM
MAD King MAD King is offline
Vacuum Canister?
Hello,
could please someone tell me the exact name of the vacuum canister that controls the vents, what is placed under the left from fender?
I lost that canister and not able to find it with "vacuum canister" online at the parts stores.
Lumina 1998 3.1
Thank you
Old 06-06-2011, 07:17 PM
maxwedge maxwedge is offline
A990 racer
Re: Vacuum Canister?
Might be called vacuum storage tank, but I believe this is a dealer part anyway.
Old 06-06-2011, 07:23 PM
Thank you. Found it. It is called vacuum storage canister. Available from Dorman.
Old 06-20-2011, 08:31 AM
Mediaman67 Mediaman67 is offline
Hi All - if this is broken, would I get good heat out the floor duct, but hardly anything out of the vents when I switch the control to VENT... or is there somewhere else I should look.
Thanks so much!
Old 06-20-2011, 08:40 AM
Thanks so much!
Exactly what was happen with mine. Look for a leak. The vacuum canister is under the left front fender, or at least should be.
Old 06-20-2011, 08:51 AM
and also AC? I assume same vacuum for both vent and AC?
Old 06-20-2011, 08:54 AM
one other question - how did you access it? from under the car, or from the air box, and then down? from inside of engine compartment?
Where did that hose connect to?
Thanks
Old 06-20-2011, 04:58 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
The vents default to hi/low (defrost and floor vents) when vacuum is lost. Doesn't matter if it's seat on heat or A/C.
There's a vac line that runs to the vac reservoir that is susceptible to getting pinched or broken when replacing the battery...it sometimes ends up in the way and gets trapped under it or disconnected.
I'd look there first if it may have been a possibility...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 07-19-2011, 10:28 PM
teegolf teegolf is offline
Canister is accessed from below the car. The Dorman model is not a OEM replacement and you will have to modify mounting in order to install it.
Old 08-14-2011, 05:36 PM
dinok dinok is offline
you can find it if you take left driver side wheel off and get that plastic protection guard, and those lines are really easy to brake, so you can buy fro autozone or other part stores the lines to replace.
If you can find another one of those vacum canister form junk yard, or dealer, it's easy thing to replace.
Vacuum Canister bmason357 Caprice 2 10-12-2007 12:37 PM
vacuum canister? tat2dbaldguy Cherokee 5 04-18-2005 08:02 PM
fuel leak around vacuum canister keebop Rodeo | Passport | MU 4 02-16-2005 10:49 PM
