Go Back   Automotive Forums Car Chat > Subaru > Outback
Old 06-06-2011, 07:07 AM
ecamc ecamc is offline
Send a message via AIM to ecamc
Question A/C belt squeal - 2002 Outback
UPDATE : Resolved. Simple fix, the belt(s) were loose. Went ahead and replaced the belts and had them adjusted properly, everything is working great now.
Gang,
My wife's 02 Outback squeals when I first start the car, and then turn on the A/C. If I turn the A/C off the squeal immediately goes away. Most of the time if I let the car idle for 15-20 seconds, or start driving, I can turn the A/C on and little or no squeal. It's usually fine unless I need to really get into the throttle, like going up a steep hill, then it will squeal again, but usually settle down after I let off the throttle.
I also noticed it squealing (slightly) a couple of times under those load conditions with the A/C off.
So my question is it the A/C compressor pulley going bad, or could it be an idler pulley? The A/C works fine but the squeal is crazy annoying.
Thanks,
Ed
Serpentine Belts & Tranny Fluid Don't Mix!- HELP! Alphabravo Caravan | Voyager 9 10-18-2009 03:47 PM
99 Astro Van AWD belt squeal grampsVVV M Bodies 2 08-21-2009 11:39 AM
2002 Outback code PO420 back again ursina Outback 1 05-19-2009 05:32 PM
2002 kia rio bad belt squealing ailestriker105 Rio | Rio Cinco | Pride 4 11-08-2008 10:19 AM
pre-2002 Outback Sport has 2.5 RS engine? SteveK2003 Impreza/9-2x/Outback Sport 12 12-26-2004 06:36 PM
