Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-06-2011, 02:33 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Reman crank
Brief background: 97 gsx has an ongoing tap, has had a near complete rebuild.
I've come to replace an aftermarket crank that kept botching the rod and bearing in the #1 cylinder. I believe it is Chinese made and probably doesn't meet oem standards. The crank I received now is oem remanufactured. I received matching undersized bearings to fit it perfectly. Main bearings are .5 and rod bearings are .25. I installed 1 & 4 pistons and confirmed the crank worked as designed. I installed 2 & 3 and then turned it again. Nothing moved. Even though they are torqued to spec, the #2 would not spin. Found the #2 on the crank is not undersized (meaning the .25 undersized rod bearings were not allowing movement.) I took new standard size bearings I had and installed them only on the #2 rod and it fixed the issue. I understand that this means that the crank is also off balance by a gram or 2, but my concern is if this will throw off the compression or possibly damage the engine if I decide to install it as is. I know there are some "what if" scenarios out there, but I'm asking because I want to know if any of you have done this or had issues like this before. Thanks.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 06-06-2011, 11:47 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Reman crank
Wow, I think I would be returning the crank to wherever you got it from... Might work now turning it by hand, but God knows what would happen if you tried to put higher RPMs to it. Probably would be so out of balance that it would damage something or throw a rod... Where did you get the crank from?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 06-08-2011, 02:54 AM
Re: Reman crank
Turns out I was close but not right. I got the crank from autozone who got it from crankshaft rebuilders Inc. I had the crank measured but that turned out fine. One of the 8 rod bearings turned out to be .5 instead of .25. I wouldn't have known by looking at them. I confirmed previously that all were stamped showing .25. Guess one went into the wrong machine and got stamped wrong. I'm going to stop by a local shop and get another set to make sure they all match.
72 Beetle - trashed
92 Talon - sold
Anti-Theft Window Crank Device ? Intuit Escort 6 10-11-2011 02:00 PM
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 06:25 PM
1998 Express Cranks but no Start kmckev2 Express | G Van 5 01-07-2010 11:26 AM
2000 gtp - crank sensor replacement kozmosis Grand Prix 2 08-27-2009 10:18 AM
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
