Old 06-04-2011, 07:11 PM
glc4123 glc4123 is offline
1997 pontiac gp drive axle boot replacement
yes, i want to change the boot on the outer cv joint, what is the procedure for doing this? do i have to pull axle out of transfer case?
Old 06-04-2011, 10:12 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 1997 pontiac gp drive axle boot replacement
your car doesn't have a transfir case.
At the very least you'll have to remove the axel from the spindly. To do so, unbolt the axel nut, remove ball joint nut and pop it out the lower control arm, then you may have enough room to install a new outer joint boot without remove the axel from the trans. Just make sure to crimp the new boot tight enough so it doesn't come apart again.
Mine came apart too. Second time in 3 years. I guess I should consider myself lucky all things considered
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-05-2011, 05:17 AM
thanks for the reply
Old 06-05-2011, 09:10 AM
tblake's Avatar
In God We Trust
Wait, brain fart. To replace the outer boot, you'll have to disassemble the shaft. Sorry. Not sure what I was thinking last night.
Have you thought about just replacing the shaft? New ones around here rung about 60.00 at the parts stores.
Old 06-05-2011, 12:10 PM
yes, i would rather replace shaft it is on the driver side, is this a large job? also is there a procedure on the forum in steps in replacing shaft? thanks again for the help
Old 06-05-2011, 12:30 PM
tblake's Avatar
In God We Trust
To remove it, just follow the instructions in my post, #2, with the addition of using a pry bar to pry it out of the transaxel. Just be careful to not harm the shaft seal. There is a collapsable snap ring in there that takes some force, but it will come. Install the new one in reverse order and torque the nut to the proper spec. If I remember right, right around 130ft/lbs.
Changing the driveaxle boots on a 944 S2 Dr944S2 924/944/968 0 10-08-2010 02:59 PM
Issue with drive axle boot? henry79 Grand Prix 4 02-26-2008 10:08 AM
'99 Front axle boot replacement Thing1 Suburban 7 12-31-2005 09:16 PM
