Old 06-03-2011, 09:54 PM
cadman20 cadman20 is offline
1997 GTP problems
1997 GTP, keeps blowing 30amp fuse, throwing code P1652 (Cooling Fan 2 Relay Control Circuit Malfunction), pulled the drivers side fan and jumpered it, does not work. Got a new one coming in tomorrow.
The A.C. has quit blowing cold air, compressor cycles on for about 10 seconds and off for about 30 seconds. Static pressure (did not check until after I pulled the fan) is 82 PSI low side and 80 PSI high side. Ambient temp. was in mid 90's. No leaks to be found.
Does the condensor fan not working affect the A.C. or should I plan on looking at something else?
Thanks in advance,
Joe
Old 06-04-2011, 11:25 AM
Re: 1997 GTP problems
O.K. changed out the fan motor, buttoned everything back up and turned on A.C. the compressor kicked on and stayed on like it should, blowing cold air.
Both fans are running while the A.C. is on, everything works, not gonna question why, just glad it does.
Joe
Old 06-04-2011, 10:00 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
yes, the fans not working could affect your comprssior cycling. Just to clarify.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
1997 GTP Overheating problems gtp3.8 Grand Prix 6 07-15-2010 12:50 PM
1997 GTP problem ToneDef Grand Prix 1 03-22-2009 09:19 PM
1997 GTP AC problem gtp3.8 Grand Prix 3 10-01-2008 09:25 PM
1997 GTP electrical problem joker1s Grand Prix 2 06-26-2008 06:58 PM
1997 GTP 12-disc cd changer problem Kraut18 Grand Prix 3 04-18-2008 07:19 PM
