Old 06-03-2011, 06:31 AM
charlie40 charlie40 is offline
98 taurus disable
can anyone tell me how to reset or totally disable the factory alarm sys in a 98 taurus.
Old 06-03-2011, 06:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 taurus disable
By alarm system, you're referring to the one that honks the horn rather than the one that will prevent the car from starting, correct? Are you looking to disable it because it randomly goes off? If so, I bet your door ajar light also comes on and the problem is a dirty door ajar sensor, probably in the driver's door. It may be easier to fix this, since it could also drain your battery, than to disable the alarm.
-Rod
Old 06-03-2011, 07:26 PM
shorod's Avatar
SHO No Mo
Since, per your PM, it sounds like the Passive Anti-Theft Security (PATS) system is the one causing the no start condition, this would not be something you can disable. It is programmed to work in conjunction with the specific ECM in your car.
Maybe provide a few more symptoms will help us help you. Does the Theft/Security indicator blink rapidly when you attempt to start the car? Since in your PM you mention "...wont let the car start. will not do anything . will not turn over." I'm curious if the radio turns on, interior lights, etc. If the radio doesn't work when the key is turned to Run either, then the problem is not the security system.
Also, please reply to this post rather than via Private Messages so others can see the details and provide input as well.
-Rod
Disabling Automatic Headlights - 1997 Regal GS TrinaR1231 Regal 1 12-04-2010 05:37 PM
2004 LeSabre: How do I disable automatic headlights? Audire LeSabre 11 11-28-2009 01:05 AM
2000 Taurus Fuel Pump wrong Guage Readings DCV Taurus | Taurus Wagon 3 07-04-2009 05:46 PM
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
99 Ford Taurus Waterpump Rust Damage mcdyver1 Taurus | Taurus Wagon 2 05-25-2009 07:36 PM
