Old 06-02-2011, 07:32 AM
dpalomaki dpalomaki is offline
2004 Speedometer intermittent
2004 Limited - The speedometer will, occasionally start to display incorrect speeds, usually way too slow, like half or less. Usually shutting down and restaring the car will correct the speedometer display. Mainly happens only after driving the car for a while (20 minutes or more) but may not happen at all. However, the heads-up display shows correct speed even when the speedometer is off, the oodometer appears to be correct.
Any ideas?
Old 06-08-2011, 09:49 PM
Jrs3800 Jrs3800 is offline
Re: 2004 Speedometer intermittent
Chances are that the step motor for the speedo is failing..
The Following User Says Thank You to Jrs3800 For This Useful Post:
dpalomaki (07-15-2011)
Old 07-28-2011, 05:56 AM
Stepper motor replacement solved the problem!
Thanks
Old 07-28-2011, 02:14 PM
happydog500 happydog500 is offline
Jrs3800 solves another one!!!
Chris.
P.S. First try, right on the money!!
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
'99 Legacy Outback- Speedometer Intermittent jtg1969 Legacy / Liberty / Baja 5 01-01-2016 02:52 PM
98 Ford Contour Speedometer intermittent mello4182 Contour 1 04-16-2008 12:59 PM
2004 Speedometer Problem cdash Impala | Impala SS 2 05-08-2006 10:52 AM
Speedometer Intermittent / Dead GregA Cherokee 2 11-27-2005 11:07 AM
2002 - 2004 Speedometer Cluster MrKill Grand Cherokee | Grand Cherokee SRT8 1 07-01-2004 10:28 PM
