Old 06-01-2011, 08:42 PM
MAD King MAD King is offline
Weird A/C Cooling Fan Problem
Hello,
I have a very weird issue with my A/C. When the A/C is on, and I do not accelerate, the Vent on the dash is working fine and blows cold air, but as soon I accelerate, it stops. When I turn the A/C off, it blows normal.
What can this be?
Thank you
Old 06-01-2011, 10:47 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Weird A/C Cooling Fan Problem
Your W-car's black plastic vacuum line is broken at the point it passes by the battery-- battery gases deteriate the line- make it brittle--once you repair this, the vents will work normally- they are losing vacuum control due to the vacuum leak in th eline. Use a small rubber hose to splicce the line. I have seen slip-shod mechanics set the new battery on this line and break it.
Seen this problem maybe 150 times.....This is a Lumina sedan and not the APV correct? if APV, it does also apply- but vacuum leak is at the power steering pulley usually.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-01-2011, 10:58 PM
Thank you so much for a fast response.
Where do I find this plastic vacuum line?
Where is it located? Are there pictures out where it shows the line and is it difficult to repair?
And yes, it is the Sedan 3.1
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 10:03 PM
help with a 92 spirit cooling fan backyardmec_an_ic General Discussion 1 10-30-2009 09:57 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 09:08 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 09:50 PM
A/c And Cooling Fan Problems In 99 Cavalier addycakes Cavalier 2 10-06-2004 10:33 PM
