Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-31-2011, 11:24 AM
97explorersport 97explorersport is offline
ABS/Traction control code/light
Would a broken rear e-brake cause this code ?? I believe that if one brake was draging it would cause the wheel speed sensor to give a false reading !! Any replies would be appreciated Vehice is a 2001 M/C
Old 05-31-2011, 07:16 PM
maxwedge maxwedge is offline
A990 racer
Re: ABS/Traction control code/light
The actual speeed of the wheel is what is critical to the abs, to be sure here you need to have it scanned for abs codes.
Old 06-01-2011, 07:45 PM
I understand what your saying BUT I've been trying to keep away from the stealership. Their labor rate per Hr is no real........
Old 06-02-2011, 10:51 AM
A990 racer
Many independents can do this with a high line scanner.
ABS and Traction Control Lights on after Jump start jbinramona Seville 5 05-11-2011 08:45 AM
ABS Traction control Module (HELP) ohio45344 Park Avenue 3 01-03-2011 09:53 AM
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 10:11 AM
02 Rendezvous - ABS/Traction Control Issue RGrizzzz Rendezvous 2 11-25-2009 04:04 PM
error codes for ABS/Traction control papiot Park Avenue 0 11-22-2004 12:18 AM
