Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-30-2011, 04:00 PM
Wnt2bsleepin Wnt2bsleepin is offline
2000 Chevy Malibu, Won't go over 4k RPM
I have a 2000 Chevy Malibu base and the engine will not go over 4,000 RPMs. Upon reaching it, it oscillates between 3500 and 4000 as long as I hold the accelerator down. We have gotten a lot of rain here in NY, and I may have driven through a puddle at some point. Any help is appreciated. Thank You.
Old 09-24-2011, 06:15 PM
good2us good2us is offline
Re: 2000 Chevy Malibu, Won't go over 4k RPM
If the car is in "park" or "neutral", then that's exactly what should happen. The PCM restricts the engine to 4000 RPM when not in gear. It also holds the motor in gear to a maximum of 6200 RPM or 107 MPH, whichever comes first. If it's in "drive", then the problem is most likely the "park/neutral position switch" located under the linkage on the top of the driver's side of the transaxle. It could defective, or simply misaligned. I hope that helps.
Old 09-25-2011, 02:17 PM
maxwedge maxwedge is offline
A990 racer
It is called a rev limiter as stated, so no one can "accidently" over rev the engine in nuetral/park.
problems with 2000 chevy malibu! f1fiftyguy Malibu 4 09-25-2006 04:36 PM
2000 Chevy Malibu Serpentine belt debricus Malibu 4 03-11-2006 11:34 PM
2000 chevy malibu ls gauges not functioning right. gwarnut Malibu 0 06-26-2005 12:35 PM
2000 Chevy Malibu Problem mstngcobrasvt98 Malibu 2 05-14-2004 09:38 PM
reprograming keyless entry 2000 chevy malibu lorelirusty General Discussion 1 02-23-2004 12:27 AM
