Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-29-2006, 04:58 PM
f1fiftyguy f1fiftyguy is offline
problems with 2000 chevy malibu!
while driving it stalls out and now its beginning to shut off. it seems that its not getting gas or getting to much gas, when this occurs the car loses all power and when i let off the gas it jurks really hard. if i sit and idle in park once i take off it starts but if i crank up it takes awhile before problem starts. check engine light has came on twice the first time it came back EGR valve (didnt replace)and now it came back O2 sensor(havent replaced yet) dont want to spend money on trial and error. if anyone can help it would be appreciated. oh yeah, sometimes wont start up in morning
Old 08-30-2006, 12:45 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: problems with 2000 chevy malibu!
Welcome to AF. Please delete your duplicate post, it just clutters up the forum. Also, please post your engine size and the exact codes it came up with, that will help us help you.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-30-2006, 03:05 PM
tractorboy's Avatar
tractorboy tractorboy is offline
also which O2 sensor, i think there are 2, one b4 the cat and 1 after the cat.
how many miles
last time spark plugs and wires changed
air filter
Old 09-09-2006, 04:21 PM
reese0123 reese0123 is offline
hey sounds like mine..its doing the same thing..did you ever get yours fixed???
Old 09-25-2006, 04:36 PM
Fixedmine Fixedmine is offline
Mine had the same problem,this is how I fix it.Found out the problem was in the vacuum system.Chevy put cheap plastic hoses on the system leading from the engine to the egr canister.Found your egr valve,trace to where it leads down to the back of engine,it should lead into a metal tube.I found a hole in mine(the plastic tube),used shrink plastic on the tube,no problem since.
