Old 05-29-2011, 03:20 PM
3echo9 3echo9 is offline
2004 CV half shaft replacement
Anyone know of a good write up for replacing the half shafts in the 2004 LeSabre?
Getting a vibration over 55mph. Same thing happened in a 1992 LeSabre I owned. The dealer replaced the driver side inner shaft.
Along the same line..Rock Auto shows many different options for CV Half Shafts. Anyone know why the AC Delco are up to 10X more expensive? What are you getting that you aren't getting with the other manufacturers? Just curious.
2005 Chevy Equinox LT 186,000 mi
2004 Buick LeSabre 200,860 mi
2011 Infinity G37x 103,000 mi
Old 05-30-2011, 07:38 AM
maxwedge maxwedge is offline
A990 racer
Re: 2004 CV half shaft replacement
AC is is always more, I would think they have stricter guidelines for the rebuilding process. Autozone.com, repair guides has decent instructions.
Old 05-30-2011, 08:21 PM
I noticed that there are two options for ordering replacement half-shafts depending on Option code FQ3 (2.86 gear ratio) or Option code F83 (3.05 gear ratio). I don't have the original window sticker. Do you know of any other way to determine which gear ratio the car has? VIN? My LeSabre is a Custom btw.
Old 05-30-2011, 08:27 PM
A990 racer
Look at the rpo tag on the spare tire cover.
New CV half-shaft doesn't fit? mfsoler Cavalier Problem Diagnosis 0 06-23-2010 01:53 AM
93 Izusu Rodeo front half shaft replacement bouldercreekgreg Rodeo | Passport | MU 3 02-24-2007 02:10 AM
Half-shaft replace HyperV594 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 10-02-2004 09:40 PM
CV half shaft replacement process dvettman Camry/Camry Hybrid/Vista 0 09-13-2002 04:05 PM
half-shaft replacement PaulD Engineering/ Technical 4 07-15-2002 04:16 PM
