Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-23-2007, 09:24 PM
bouldercreekgreg bouldercreekgreg is offline
Question 93 Izusu Rodeo front half shaft replacement
I am replacing the front rotors on V6 automatic with rear disk brakes and noticed driver's side half shaft boot was split.
I pulled the spindle and attempted prying the half shaft out!
It wont budge.
There is no plate on the differential, so it doesn't use Chevy type horse-shoe retainers to retain the shaft.
What do I need to know to pull the shaft out?
Input much apprerciated.
Thanks, bouldercreekgreg
Old 02-23-2007, 11:28 PM
Cat Fuzz Cat Fuzz is offline
Re: 93 Izusu Rodeo front half shaft replacement
You have to cut the inner most boot clamp, pull the inner boot back, remove the large spring clip inside the inner CV joint housing, then pull the axle out. The inner CV housing stays in the truck. You'll need a new CV clamp for the inside.
Old 02-24-2007, 12:06 AM
Smile Re: 93 Izusu Rodeo front half shaft replacement
Hi Cat Fuzz!
Thanks a bunch. Makes total sense! THANKYOU!
Wonder just what kinda nightmare is involved in replacing the inner shaft?
Thanks again, Greg
Old 02-24-2007, 02:10 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I was going to post a link the the diff drop bracket write up in case you really wanted to know But couldnt find it. They involve the same work since you have to drop the differential and remove the inner cv cups to change the brackets.
Here is a quote from Strawmyers after modifying some stock brackets and installing them though..
Between fabbing the brackets, fabbing the crossmember, teardown/installation/reassembly, and cleaning up; this project took appx. 20 hours. On the 'scale of things I'd like to do twice', this ranks slightly below getting punched in the face.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
