Old 05-29-2011, 08:56 AM
jerry1967 jerry1967 is offline
blower motor testing
I have 2003 Buick Lesabre 3800 engine. For a while I could kick under the dash on the passenger side and the blower fan would come on. Now nothing happens.
How do I tell if the problem is the resister or the blower motor?
Is there a way to test the blower motor before I buy one?
Old 05-29-2011, 10:53 AM
imidazol97 imidazol97 is offline
AF -Advisor
Re: blower motor testing
If it were the resistor on the basic model or the electronic control on the Limited, you'd have different symptoms: the fact that it reacted to vibration getting the brushes back in contact with the commutator worked for a while is the telling factor.
Your blower motor most likely has worn the brushes out or one is sticking in its channel. Just replace the blower and be happy.
Old 05-29-2011, 03:43 PM
Scrapper Scrapper is offline
AF Premium User
i agree on getting motor and fix it rite..
Old 05-29-2011, 07:27 PM
thank you I will try and tackle the job tomorrow and let you know the out come.
Old 05-29-2011, 09:54 PM
brcidd's Avatar
brcidd brcidd is offline
Kicking blower motor IS the test to determine if blower motor is worn out--yours is worn out-- replace it.........
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-30-2011, 05:38 PM
AF Premium User
yes you kicked it for the last time huh? lol.... just like a starter and a hammer.
good luck.....
Old 05-30-2011, 07:28 PM
Well I took the motor and fan off and tested it and they tested good. So I hooked the wires up to the car and the fan ran on all speeds. So I guess it is working now but I am afraid if I put it back on it will stop again.
By the sounds of everybody I should just get a new one. I was hoping to save some money but guess that is out of the question.
Old 05-30-2011, 09:22 PM
brcidd's Avatar
steel toed shoes?
'99 GMC Yukon
Old 05-31-2011, 06:43 AM
AF -Advisor
Since you've had it out and it now is working, you can put it back in and see how much mileage you get out of it before it stops again.
Did you check the connector for overheating and corrosion? That's a low possibility. I don't see that mentioned after the first couple of years on this model (2000-2001).
You don't have much to lose other than the time it took you to take it out and put it back in. And now if it does fail, you're a pro and can do the job in half the time? Grin!!!
I'd shop around for the replacement. I found nobody stocked them in the big box stores locally except Autozone despite their being a failure item in Bonnies and leSabres. I went to one of two locations which had them in stock on my way to a car show that afternoon. $139. Apparently they tried to keep one at each store. If it sold, then they had to wait for a replacement in their regular shipment.
Check prices on Rockauto and look online for discount code for 5% off. I've found Rockauto to be quick on delivery.
Old 05-31-2011, 06:55 AM
brcidd's Avatar
If your 2003 blower motor is silver--- get ready for a hassle---you need to buy the adapter ring that it mounts to because the replacement blower rmotor will mount differently. I lost about 4 hours trying to find the proper blower motor- finally googled it and found the adapter part number on my silver OEM replacement.
RockAuto has footnotes describing this god awlful replacement procewdure.
That adapter ring ($29 at dealer) is a real PITA to replace.
'99 GMC Yukon
Old 05-31-2011, 10:41 AM
AF -Advisor
My 2003 did not need that. The Autozone replacement went in perfectly.
Old 05-31-2011, 10:49 AM
brcidd's Avatar
It's a midyear changeover thing---silver was the key-- VIN will confirm
'99 GMC Yukon
Old 06-01-2011, 07:02 AM
Did the replacement you used have the adapter ring on it?
Old 06-01-2011, 07:10 AM
I took it out and tested it and everything worked fine so I put it back in and I found out the connection is loose. I am going to use the one I have until it stops again but still looking for a replacement.
imidazol97 said the one he got from autozone worked fine so I am going to look at theirs.
Old 06-01-2011, 07:46 AM
brcidd's Avatar
Is your blower motor silver? That is the key- if silver, you need the adapter
Mine was silver.
Mine from Autozone- would not fit-- I actually took it back, raised cane-- until I learned of the adapter ring. Autozone was clueless- had no notes on it-- but just look it up in any parts catalogue....
,BLO(W/IMPLR) WHEN REPLACING BLOWER MOT W/FOAM GASKET, WILL ALSO REQ USE OF BLOWER MOT BRACKET P/N 88957446 T/W 3 BOLTS 89018611; w/A/C FRT AUTO/AUX CONT(CJ2) or A/C FRT ELEC CONT(C67
'99 GMC Yukon
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
2004 Blower Motor Related Electrical Issue... cableguy83 Impala | Impala SS 3 05-24-2011 04:54 PM
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
'97 Grand Prix GT Blower Motor Resistor olopezm Grand Prix 11 06-10-2010 03:20 PM
06' COMMANDER blower motor always runs bclark001 Commander | Patriot 0 03-22-2010 11:39 AM
