Old 05-29-2011, 12:25 AM
1994cavalier 1994cavalier is offline
100 Octane gas?
I have a 94 cavalier 2.2 L and i was wondering if you guys think 100 octane would be ok to use in my car.
possible benefits may be increased fuel mileage, cleaner emissions and better Throttle body response
what do you guys think? and safe to use??
Old 05-29-2011, 09:23 AM
j cAT j cAT is offline
Re: 100 Octane gas?
since your vehicle was designed to operate on 87 octane the use of any octane above 89 would be a waste...
100 octane could cause engine damage since this engine is not calibrated for this fuel..
if you have this fuel and need to use it up mix some in with the 87 octane..
Old 05-29-2011, 10:22 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 100 Octane gas?
Don't use 100 octane. It's probably aviation fuel intended for airplanes and probably has tetra-ethyl lead in it. If you use enough of it your catalytic converter will become coated in lead internally, rendering it ineffective. This means you will have to get a new one installed so you can pass the next emissions test.
Old 05-29-2011, 05:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 100 Octane gas?
In addition to these good reasons not to use it, burning higher octane gas can actually lead to pre-ignition (knocking/pinging). It burns slower which is why it's needed in high compression, boosted engines, or in applications where the timing is advanced more that "standard" engines.
If you use higher octane than what the engine needs, this slower burning means it's not all burnt, and that will lead to carbon deposits in the engine. Over time they will build up to the point where they create a big enough hot spot, and will eventually ignite the fuel/air mixture before the spark occurs.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-30-2011, 09:00 AM
Re: 100 Octane gas?
as mentioned by the other members if this is aviation gasoline it would be blue in color and have 2 grams of lead per gallon...with cat converters this would mess up the emissions ...even in small amounts..
called LL100...........
Old 05-30-2011, 11:33 AM
Re: 100 Octane gas?
Hey thanks for your guys' input! will def not put that stuff in my car
93 Octane VS. 87 Octane Gas freesiagirl Metro 4 09-03-2007 06:11 PM
100 Octane! unknownluder69 Prelude 2 11-07-2004 10:17 PM
SoCAL 100 octane gas pumps!!!!! Savior1974 Off-Topic 14 10-26-2004 06:13 PM
Is 87 octane gas with octane booster as good as 93? Spectre120 Camaro Discussions 28 10-20-2004 06:51 PM
Octane Boosters and 89 or 93 octane gas blazzingbrandon 4Runner/GX470 2 08-29-2004 03:02 AM
