Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 05-28-2011, 11:25 PM
1994cavalier 1994cavalier is offline
100 Octane gas?
I have a 94 cavalier 2.2 L and i was wondering if you guys think 100 octane would be ok to use in my car.
possible benefits may be increased fuel mileage, cleaner emissions and better Throttle body response
what do you guys think? and safe to use??
Old 03-19-2012, 06:37 PM
Zeifer Zeifer is offline
Re: 100 Octane gas?
It would be safe as far as I know but there will be absolutely no increase in power/mileage/response/whatever, especially on a stock motor.
The octane number pretty much just measures how resistant the fuel is to detonation (due to pressure). That's why boosted and high compression cars are to run on higher octane, because due to the increased pressure, the fuel will detonate before it needs to causing knocking and possible engine damage.
http://www.nicoclub.com/archives/gas...ane-myths.html
Old 09-05-2012, 09:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 100 Octane gas?
Agreed, in fact if there was any difference, you'd probably lose gas mileage and have worse emissions. Higher octane burns slower, and 87 octane isn't completely burned by the time it goes into the exhaust. With higher octane, less gets burned in the cylinder.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-24-2012, 03:33 PM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
Re: 100 Octane gas?
octane is a commonly misunderstood thing. higher octane doesn't mean higher power. An engine that is designed for higher octane will perform better with that octane.
93 Octane VS. 87 Octane Gas freesiagirl Metro 4 09-03-2007 05:11 PM
100 Octane! unknownluder69 Prelude 2 11-07-2004 09:17 PM
SoCAL 100 octane gas pumps!!!!! Savior1974 Off-Topic 14 10-26-2004 05:13 PM
Is 87 octane gas with octane booster as good as 93? Spectre120 Camaro Discussions 28 10-20-2004 05:51 PM
Octane Boosters and 89 or 93 octane gas blazzingbrandon 4Runner/GX470 2 08-29-2004 02:02 AM
