Old 05-26-2011, 10:39 PM
IMtnBike IMtnBike is offline
High fan blower doesn't work 1996 Jimmy
My high fam blower stopped working on AC or heat on my 1996 Jimmy 4x4. Any suggestions what can cause this and how I might fix it?
Thanks for your help.
Jeff
Old 05-26-2011, 11:01 PM
brcidd's Avatar
brcidd brcidd is offline
Re: High fan blower doesn't work 1996 Jimmy
Typically, the high speed blower motor relay is shot, but check the voltage to it is good.
Relay is at right rear of engine compartment-- follow the purple wire from blower motor back to relay- then tap on relay while ignition is on and blower speed selector switch is on high- if blower comes on- replace relay, (or tear it apart and file down burnt contacts).
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
blazee (07-25-2011)
Old 05-26-2011, 11:05 PM
1996 Jimmy A/C fan switch problem
My fan switch does not work on high only. Any suggestions of a cause and how to fix.
Thanks,
Jeff
Old 05-27-2011, 02:17 AM
viggy58 viggy58 is offline
Re: 1996 Jimmy A/C fan switch problem
is that manual or auto climate control?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 05-27-2011, 07:21 AM
brcidd's Avatar
here is another answer
'99 GMC Yukon
Old 05-27-2011, 07:25 AM
rprough's Avatar
rprough rprough is offline
This is more than likely a fan speed controller gone bad. Its located in the ac/heater duct housing in the engine compartment. Should be about three to 4 wires going to it. Easy fix.
Old 06-21-2011, 05:58 PM
maxisp2000 maxisp2000 is offline
Where is that? Behind the blower motor? Behind the dash?
My high blower only works in temperatures below 90°; if the AC runs long enough the high will work.
Old 06-22-2011, 06:28 AM
rprough's Avatar
Its usually in the engine compartment, right next to fan blower motor, passenger side. Like I said, its in the housing. The fact that your ac working for a bit mzkes it work syas its cooling the speed controller down.
God Bless America
Old 07-19-2011, 06:28 PM
Actually, the fan control inductors work on speed 1-3. That's in the duct. The high speed fan runs through a relay that is connected through a large round factory connector between the firewall and the VCM.
I tracked my wires and found out the connector was fried inside. I replaced the connector with bullets and now the fan works at every speed, hot or cold.
Old 07-20-2011, 04:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Not sure what kind of bullets you used.
But.
Best to solder all wiring connectors and make sure all push on connectors are tight.
Lose wire or connector will build up heat and fry itself and other stuff with it.
MT
Old 07-24-2011, 10:32 PM
Thanks for the reply. You were exactly right. I replaced the relay on the firewall and it works great. Thanks again.
Jeff
Old 07-24-2011, 11:59 PM
Too cool. How about a thanks?
Old 07-25-2011, 12:24 AM
blazee's Avatar
blazee blazee is offline
Problem?
Good call brcidd.
Jeff
1996 Jimmy A/C fan switch problem IMtnBike Problem Diagnosis 4 07-14-2010 08:14 AM
1996 jimmy hazard button broke 96jimmy4doorstock Problem Diagnosis 3 08-06-2009 12:33 AM
1996 Jimmy replacement of gaslines 600cuin Jimmy 0 06-22-2009 02:26 PM
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 07:38 PM
1996 jimmy 4.3L 4x4 switching problem not going back to 2wd mertseckn Jimmy 3 08-21-2007 06:40 PM
