Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-26-2011, 10:43 AM
bennuss bennuss is offline
A/C Clutch
How can I tell if the ac clutch is engaging? I checked the fuse and relay in the box under the hood. Good. I have a buick century 2005. I also checked the pressure at the low pressure valve when the unit is on and it shows 35 psi which the gauge says is fine.
Old 05-26-2011, 07:16 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: A/C Clutch
If you can see the compressor then watch the front of it while someone turns the AC on and off. You should see and hear it engage. It will move slightly and then turn with the belt otherwise it should remain stationary.
Old 05-26-2011, 07:27 PM
Re: A/C Clutch
Any suggestions what else I should check. I checked the fuse and relay in the box next to the battery. The refrigerant pressure is ~35psi which should be sufficient.
Old 05-26-2011, 09:42 PM
brcidd's Avatar
brcidd brcidd is offline
Re: A/C Clutch
35 psi is great if compressor is running-- it is rotten if compressor is not runnning- means you've lost 95% of your refrigerant.
Compressor won't come on until static pressure is 47 +psi...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-26-2011, 09:59 PM
Re: A/C Clutch
it is 35psi with car and ac turned on. with car off i get over 50 psi. I guess that means that my ac clutch is engaging. But the air coming into the car is warm. not getting cold at all. any suggestions. are there other things to check?
Old 05-26-2011, 10:37 PM
brcidd's Avatar
Re: A/C Clutch
You are low on refrigerant and need to add about 2 cans--- after you find and fix the leak....
'99 GMC Yukon
Old 05-26-2011, 10:49 PM
Re: A/C Clutch
thanks for the quick response. Is 35psi good or no good. If the pressures are different with car on 35 and with off over 50 am I correct that the compressor clutch is engaging? anyways do you recommend using the dye to find the leak ? should i use the seal leak stuff. (used it once on an acura and it it still going strong after 4 years)
Old 05-26-2011, 10:53 PM
brcidd's Avatar
Re: A/C Clutch
Most likely a compressor shaft seal leaker...
If you use leak sealer- don't ever bring it to me-- that stuff will ruin a recovery machine!
Dye is already in your system- Dye was introduced in GM vehicle OEM in 2002 model year. Get out your blacklight and UV glasses (sold at Autozone $12) and leak for leak evidence- it will glow bright fluorescent green.
'99 GMC Yukon
JETTA Clutch Trouble... HELP! m007steve '97 - '03 0 08-02-2010 04:43 PM
2003 mustang gt clutch Drewet88 Performance 0 05-03-2010 01:40 AM
89 clutch replace? Hard? auto89 Pick-Up 0 03-04-2010 07:18 PM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 01:17 PM
Installing a clutch pedal assembly towelie Ranger | Courier 1 02-15-2009 08:18 PM
