Old 05-25-2011, 07:23 AM
goongrinch goongrinch is offline
05 cadillac escalade engine light
6.0 ext model....engine lights been on.....plugged in my scanner and no communication, checked fuses and all good, looked at cigeratte lighter port and there where coins in there, usually its a simple fuse fix on other cars along with taking the coins out of the port and replacing the fuse, mostly because the cig lighter is linked with the obd connecter on a majority of cars, and people store their coins in the port.... but simple case i cant get my scanner to link up any tips?
Old 05-25-2011, 12:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 05 cadillac escalade engine light
Have you ever successfully used this scan tool on this Escalade? Your Escalade probably uses a CAN protocol and your scan tool may not support the protocol used by your 2006 Caddy.
Does your scan tool have it's own battery or does it get power from the OBD-2 port? If it gets power from the port, you know the fuse is not the problem.
-Rod
Old 05-28-2011, 01:35 PM
well the cig lighter doesnt work either so im asumming the data connecter and the cig lighter run off the same source. since ive seen cars in the past with this same problem, its just i dont have a wiring diagram.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 04:06 PM
