Old 05-24-2011, 07:20 AM
drw7162 drw7162 is offline
Dangerous Pause while driving
Hello all,
I have a 2001 gmc jimmy with a rebuilt transmission. I have 145K on it now and rebuilt the tranny at about 73K. I will go to take off and sometimes when I press on the gas pedal it goes to the floor and nothing happens! The engine doesn't rev, it deosnt sputter and it doesn't stall, it just keep running like I didnt press the gas pedal. This of course is very scary when you are turning and traffic is coming at you. I usually have to release the gas pedal and press it again and it works. Sometimes it does it while the truck is already moving also. This usually happens in lower gears. Is this my transmission finally starting to take the plunge or something else?
Old 05-24-2011, 03:13 PM
jdl jdl is offline
Re: Dangerous Pause while driving
Any applicable trouble codes? Can you get it to act up in your driveway? Work the throttle by hand, when problem occurs, see if it makes any difference? Clean the throttle-body, check tps. Intermittent issues can be a pain to track down. How long since a tune-up? Check fuel pressure.
Old 05-24-2011, 03:26 PM
I was planning on testing the tps tonight and Ill get back to you with the results. Thanks!
Old 05-24-2011, 03:40 PM
jdl jdl is offline
With intermittent issues, you have to test when problem is ongoing. I realize that is hard to do going down the highway. Any trouble codes? To check yourself, at the least, you need an obd2 code reader. Some of the national brand autostores used to check codes for free.
Old 05-27-2011, 07:11 AM
ok, so I borrowed a code reader and it came up with a code for my tps, I was thinking it might be this and now Im certain, will be changing it out tonight and update on how it works it if anyone is interested.
Old 05-31-2011, 07:30 AM
I changed out the tps, cleared the code and the truck has been running so much better. No more pauses while driving yet, its even shifting in and out of gears better. Hopefully my gas mileage goes back up a little aslo, well see. Thanks for all the help!
The Following User Says Thank You to drw7162 For This Useful Post:
danielsatur (05-31-2011)
2000 Gran Prix gt 3.8 L IDLE AND RPM`S JUMPING WHILE PARKED AND WHILE DRIVING Joeyprix Grand Prix 15 01-06-2011 11:41 PM
2000 ranger misses while driving and at fast exceleration while in neuteral Bullrider_024@hotm C/K 3 11-22-2004 12:58 PM
OK got the 171-174 codes any danger to just driving rrules Windstar 3 04-26-2004 12:38 AM
