Old 04-01-2004, 12:04 PM
rrules rrules is offline
OK got the 171-174 codes any danger to just driving
I have had these codes popping on for about 6 months. I had a vacum leak that was fixed and this resulted in the the van running better. The light is on again and the van runs fine. To I need to replace the gaskets? Will I do damage to the engine if I keep driving it?
Old 04-01-2004, 01:03 PM
lewisnc100 lewisnc100 is offline
Re: OK got the 171-174 codes any danger to just driving
Assuming you've ruled out other sources of leak, here's a recent long thread on the P0171/P0174 TSB covering the 99-03 Windstars. Others on here have done the repair in a couple of hours and all the part numbers are listed in the thread.
http://www.automotiveforums.com/vbul...&highlight=171
Old 04-01-2004, 10:09 PM
amac209 amac209 is offline
Send a message via MSN to amac209
clean your maf sensor wires with an electronic cleaner. oil from the bad valve cover usually gets finds it's way onto the maf throught the breather line and throws the sensor out of wack.
good luck!!
Old 04-26-2004, 12:38 AM
toivoju toivoju is offline
Thumbs up Re: Re: OK got the 171-174 codes any danger to just driving
You got my vote! I just cleaned MAF sensor and the car runs like a new. 171-174 thing has been disturbing be something like 6 months. I have tried just about everything you can imagine and this little thing (15 mins work) solved the whole mess! Even though Ford says; don't try to open MAF, I advice everybody having 171/174 to do it FIRST! Easy and cheap help.
98 ford explorer stalling, error 171 174 hsd Explorer | Explorer Sport Trac 8 01-18-2010 11:43 PM
171-174 codes after tsb band19 Windstar 6 01-01-2008 01:21 PM
Persistant 171/174 Codes rob_2000 Windstar 2 12-28-2006 06:11 AM
171/174 code fix issues Tomb stone Windstar 8 07-14-2006 11:36 AM
171/174 codes DRW1000 Windstar 6 10-08-2004 03:45 PM
