Old 05-23-2011, 10:34 PM
timberwolf1961 timberwolf1961 is offline
k 1500 stalled, fires with ether
1989 k 1500 350ci stalled, it fires on ether but I have no voltage reading at the 20 amp fuel pump fuse on the firewall.. The fuel pump relay clicks when key is turned on. I had no symptoms of a failing fuel pump which is only a couple years old. I then unplugged the oil pressure switch under the distributor and jumpered it and now I have 12.2 volts through the 20 amp fuse, but I did not hear the pump power up and it wont start. Help.
Old 05-24-2011, 01:36 PM
Schurkey Schurkey is offline
Re: k 1500 stalled, fires with ether
If it's like my '88, the fuel pump fuse is fed by the fuel pump relay OR the oil pressure switch; and both of those source their power from the junction block on the firewall right beside the fuel pump fuse.
The fuel pump relay is triggered by the ECM at key-on for two seconds, then shut off until the ECM senses that the engine is cranking or running.
The fuel pump fuse is powered by either the FP relay or the oil pressure switch, or both.
If the fuse has power, the pump should be getting power via the tan/white wire, and therefore running.
If the fuse has power but the pump doesn't run, you've got defective wiring between fuse and pump; or between pump and ground (the pump grounds to the frame rail using a foot-long, single wire under the box) or a defective pump. The fuel pump ground is NOT one of the three wires in the fuel pump wiring harness--it's the separate wire.
There is a known, common problem with the wire harness INSIDE the tank. Most replacement fuel pumps come with a harness upgrade kit that supposedly fixes this problem. I just put a pump into my 300,000 mile '88; and there was just the faintest sign of overheating/melting at that trouble spot--but lots of folks have had problems with this. If you've installed a new pump, I'd have expected that this would already be updated...but you won't know if that's the problem without some additional diagnosis.
I can't tell from your description if the fuel pump fuse has power when the fuel pump relay is triggered by the ECM.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-24-2011, 04:40 PM
j cAT j cAT is offline
with no start and pump fuse has no voltage the relay should be replaced or tested if you have the ability to test..
when a vehicle your age has a pump failure the relay should have been replaced 2 years ago.
I have had issues with these relays on newer vehicles with voltage drop because of worn out contacts..
Old 05-25-2011, 11:03 AM
It was the ground wire at the tank broke off the frame, but I also found a worn spot on the hot wire between the plug and the fuel pump assy. to the point where the only thing holding it was one side of the wire insulation I literally just stretched it apart by hand. I dont know if I had two problems simultainiusly or what but Im glad its fixed thanks for all your input guys it really helped out.
Old 05-25-2011, 07:53 PM
thanks for the details...on your repair...frame rail ground is quite a common failure..the wire corrodes to dust !
99 Tahoe 5.7 only runs with ether shot trox Tahoe 17 12-21-2009 07:16 AM
Will Not start with Ether either gustavuks Express | G Van 3 04-01-2008 05:38 PM
1981 Chevy 1500 Doesn't Fire!!! Lilbubblebutt C/K 1 08-17-2007 12:49 PM
1991 Lumina APV only starts with ether Dan Kosek Lumina APV 18 04-24-2007 04:16 PM
Dodge Ram 1500 Stalling with no reason Dibsing Ram Pickup | Ram SRT10 15 02-02-2006 02:41 PM
