Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-04-2004, 02:22 PM
kroms_001 kroms_001 is offline
1993 GMC Jimmy 4.3 4x4 switch problem
Ok, I read ahead and disconnected the battery for 5-10 minutes and I still have the same problem:
When trying to engage the 4x4 to either upper or lower all I hear is a small "click" and it does not lock, the truck still remains in 2wd. It seems the "click" is coming from just behind the glove box. Also, it seems the lights on the 4x4 switch blink for a second - but nothing happens. I decided to take the switch appart to see if there were any bad wires, but could find no faults... I would appreciate any help I could possibly get!
Thanks,
Mike
Old 03-06-2004, 07:12 PM
poppaschafs poppaschafs is offline
Re: 1993 GMC Jimmy 4.3 4x4 switch problem
just replaced the encoder motor on my sons 93 jimmy. seems to have been the problem. expensive and hard to find though.
Old 03-07-2004, 08:34 PM
Steelpanther Steelpanther is offline
Check this out may be of some help as I just did this a month ago:
http://myrepairs.50megs.com/index.html
Old 03-09-2004, 11:58 AM
riptreeper's Avatar
riptreeper riptreeper is offline
did you try driving a couple of miles an hour and then hitting the button because i know that on my 96 it makes a weird noise when im not driving and try to engage the 4 wheel drive
Old 03-14-2004, 12:27 PM
mjohn mjohn is offline
I have a similar problem with my 1993 Jimmy...
And, when it is cold, is when I have the problem...
Like <30F. so try driving slow and putting in 4HI
Old 01-21-2006, 12:29 PM
jack45 jack45 is offline
How did you end up fixing it? I have the same problem.
Old 01-22-2006, 05:56 AM
mjohn11b mjohn11b is offline
What was the cost?
And, did You use aftermarket parts?
How much labor?
This vehicle is no better than a car at traction/etc. without 4-wheel drive.
Therefore, this is frustrating...
thanks and praise for these Forums... :o)
