Old 05-22-2011, 06:14 PM
bigT5 bigT5 is offline
1996 chevy cheyenne ignition setup
hey, I'm thinking about getting a hotter ignition setup for my 96 chevy cheyenne 1500. I'm not looking for a drag racing setup but I i was just wondering what are some good brands and if this is really a good idea and what it really does thanks
Old 05-23-2011, 05:01 AM
Schurkey Schurkey is offline
Re: 1996 chevy cheyenne ignition setup
You've already got more than enough spark power IF (big IF) the original system is working PROPERLY.
Save your money. You could add aftermarket spark boxes and such, but you won't gain power or efficiency--except that your wallet will be thinner and lighter.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-23-2011, 06:14 AM
snshddog snshddog is offline
I agree, your origional equipment assuming it is working right should be fine but if you really want to add to it I would look into MSD. There are many other good aftermarket ignition systems out there now but MSD has been doing it forever and they have kept up with new technology
Old 05-23-2011, 05:05 PM
broughy84's Avatar
broughy84 broughy84 is offline
Don't waste your money.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 05-23-2011, 06:23 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Hotter ign can cause spark to burn threw top of pistons.
Your OEM ign has plenty of spark already.
If you want to do something good for it get some new AC delco plugs and wires.
MT
Old 05-23-2011, 07:25 PM
j cAT j cAT is offline
you can get a coil that puts out a little extra voltage than OEM coil...problem is that amount of extra spark over the OEM design does nothing but cost you money !
If the vehicle has the original coil replacing the coil and plug wires with new OEM would be the proper action..using ac delco plugs..
replacing the cap/rotor and cleaning electrical connections ..also using dielectric grease in the plug wire boots keeps the electrical connections sound and free from failure.
if your engine had points and you installed an ignitor kit with a matched hi output coil then you would see a very big difference...
thats all 1970's and earlier stuff !
Old 05-23-2011, 10:17 PM
Ok another question i have is sometimes when i get on the gas or just cruising over 55 there is a miss every once in a while. i have brand new rotor,cap and AC delco plugs, I didnt replace the wires because im kinda broke but i was wondering if it could be the coil too?
Old 05-24-2011, 08:56 AM
measure the wire resistance with an ohmmeter...use the dielectric grease when re installing in the boot ends...any wires with high resistance out of the normal range/open means you need new ones..
this would be the test required first to determine misses at higher RPM.
the coil if defective would cause alot more than a random miss..
the other item would be the distributor bearing/gear etc...
Old 05-25-2011, 11:23 PM
how could i know if its a bearing or gear?
Old 05-26-2011, 08:04 AM
check that the distributor shaft/rotor does not move around too much...if the cap has acring it is a sign that the shaft is wobbling around too much...bearing check...
the distributor gear is more of distributor removal to check that this gear is not worn ...experienced person can determine this by rotor movement ..
The Following User Says Thank You to j cAT For This Useful Post:
bigT5 (05-28-2011)
Old 05-28-2011, 12:56 PM
Ok thanksIll look up on that when I get some time which should be monday or tuesday
1996 chevy z71 transmission in limp home mode jheast517 General Discussion 3 05-18-2010 07:42 AM
chevy truck help rodthe1st Engineering/ Technical 3 04-27-2010 09:26 AM
