Old 04-26-2010, 08:38 AM
rodthe1st rodthe1st is offline
chevy truck help
hello all recently started a new job at chryser tech center around the same time i blew the motor in my 95 chevy pick up(2500 5.7 rwd) not havin the time to replace it i had a mechanic buddy(hack) do the work. my problem is no spark i was hoping somebody has a wiring diagram for the ignition system as iam sometime next buying someones mitchell on demand next month i just cant wait that long u can email me @ [email protected]
thanks in advance
Old 04-26-2010, 10:08 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: chevy truck help
A blown motor is fairly generic albeit catastrophic problem description. Can you give a little more info on what your mech friend had to fix? If we know what areas he was working on, we have a better idea of what could be the cause.
This should be moved to the Chevrolet C/K forum...posting to the specific forum will let those that are most familiar with your vehicle in on what you're problem is. Luckily I happen to have a very similar truck, but there are many more of us over there.
All that being said, if at least the engine's heads were removed for repair, the first place I'd check are the grounds, the coil wires and their proper plug sequence, the distributor timing versus camshaft, and the fuses for the pump and fuel injectors.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-26-2010, 12:06 PM
thanks for the timely response, the block was cracked so the whole engine was replaced. i know im not getting spark from the coil. this is an older truck and fuse panel lid that shows the location of each fuse and relay is missing a schematic of the ignition system would be very helpful in helping me track down my electrical issue
Old 04-27-2010, 09:26 AM
jdmccright's Avatar
The RustBuster
You can find one by registering at AutoZone.com (not an actual endorsement, I mention it because it's free...there may be others) and using their free online repair manuals, which are basically Haynes in electronic format. But they include electrical diagrams for the engine and chassis. Personally, I like to just buy the book to have sitting with me when my head's under the hood. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Tags
chevy , diagram , ignition , truck , wiring
