Old 05-20-2011, 10:51 PM
cadams73 cadams73 is offline
Grand Prix/siren noise
My 07 Grand Prix GT is making a very loud siren noise.
The noise does not occur while idling.It begins as a very low but loud noise, and goes up in pitch as the car accelerates, then returns to the lower pitch as the car slows down, then stops when the car isnot moving.
Any ideas as to what this could be? I've researched the web..and come up with wheel bearing issues..but..what other things could it be?
Old 05-21-2011, 10:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Grand Prix/siren noise
Welcome to AF.
Wheel bearing is possible but normally the noise would be a lower frequency type sound. The transaxle could make a whining sound. When was the last service on it and how many miles do you have?
Timeslip 08/12/06
AF Community Guidelines
Old 05-21-2011, 08:31 PM
Thanks for the reply.... It has just under 62,000 miles. If by service you mean oil change...it was about 2k miles ago. It hasnt had service other than that....except once for replacement of the front struts at 31k.
We did the whole "lift the front end and grab the tire at the top and bottom , push and pull to check for movement" and didnt notice anything.
Thanks,
Chris
Old 05-22-2011, 09:39 AM
BNaylor's Avatar
What I meant by "service" was automatic transmission fluid (ATF) and screen filter service. The first service could be at 50K miles or 100K miles depending on use.
Timeslip 08/12/06
Old 05-23-2011, 03:05 PM
roman1978 roman1978 is offline
It sounds more like a power steering pump or the alternator
Old 05-23-2011, 07:21 PM
rickisrad rickisrad is offline
is it supercharged???
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-23-2011, 07:35 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
07 GT is supercharged.
I was thinking the same thing you are. I dont think thats the issue though because even with an open intake you don't hear the supercharger all the time.
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
2000 grand prix noisy fuel pump? xcmhs Grand Prix 1 06-22-2010 10:14 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
