Old 05-20-2011, 09:21 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Plugged heater core?
So after searching I haven't found a definite answer.
Starting yesterday being a cooler day, I noticed my heat was intermittent. I had it set on around 75 and had heat, then it seemed like it was blowing cooler, then it got hot again, so I thought I was imagining things.
This morning it did almost the same thing. Then this afternoon, setting it on 75 felt like I had it set on 65.
My first thought was the coolant was low and bypassing the heater core. I stopped at Advance Auto and picked up some coolant and topped off the overflow, as it was almost empty. The car was still hot so I couldn't check to see if the radiator needed any added.
The whole way home it was the same with almost no heat at 75, but would get hotter air if I jacked it up to 90.
The operating temperature is in the normal range so I am just looking for confirmation, or other possible solutions.
By the way, I should add the coolant system was flushed around 103k miles according to a sticker under the hood. It stands just shy of 127k now so I don't even know if a flush is an answer.
Thanks in advance.
Old 05-20-2011, 10:59 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Plugged heater core?
Hi Stealthee,
Any chance the thermostat might be sticking at the open position?
Coolant is always flowing trough the heater core so I don't think it may be clogged...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 05-21-2011, 12:41 AM
Stealthee's Avatar
If thermostat was stuck open then the operating temperature would be affected.
Operating temp is 100% normal.
Old 05-21-2011, 10:37 AM
Stealthee's Avatar
Well I flushed the heater core, and that was not the issue. The only way I get heat is if the climate control is set to 90. Anything below that and its cooler air.
Old 05-22-2011, 10:02 AM
BNaylor's Avatar
BNaylor BNaylor is offline
After engine is sufficiently warmed up how do the heater core inlet and outlet hoses feel? Paticularly the outlet hose?
Also, is the thermostat stock/OE? Rated at 195 degrees.
Timeslip 08/12/06
AF Community Guidelines
Old 05-22-2011, 10:05 AM
Stealthee's Avatar
I'll have to wait til I head somewhere to check the hoses.
As far as I know thermostat is OE. Had perfect heat all through the end of winter.
Old 05-22-2011, 12:39 PM
BNaylor's Avatar
Also, when the cooling system was serviced did the shop use Dexcool or some aftermarket extended life type antifreeze. With Dexcool the coolant will be orange. Others green/yellow.
The reason why I ask this is some switch over to the EL green but the system has to be properly and thoroughly flushed of all Dexcool or sludging may develop later on.
Timeslip 08/12/06
Old 05-22-2011, 03:04 PM
Stealthee's Avatar
It has Dexcool in it. I actually want to switch it over, but figure I'll wait a bit to do a total flush and refill.
Blend Door Actuator or Plugged Heater Core? CryptoJones Windstar 10 01-23-2011 10:33 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
Plugged Heater Core.....Again medicmandan Taurus | Taurus Wagon 12 12-20-2006 10:44 PM
suspect plugged heater core. gatopanzo M Bodies 1 07-14-2005 03:33 PM
Plugged Heater Core? CSR44 S-10 3 12-01-2004 02:50 PM
