Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-20-2011, 08:48 PM
smarks76 smarks76 is offline
strange starting problem
I just bought a used 2004 jeep wrangler 4 cyl engine it started fine for about 2 weeks and now sometimes it just wont start it just makes a clicking sound and othertimes it will start right up. But when it is just making the clicking sound and i slam my door really really hard, it will start up on the next turn. is there somekind if loose connection i should be looking for? Any help would be appreciated.
Old 05-22-2011, 05:46 AM
snshddog snshddog is offline
Re: strange starting problem
Sounds like a bad starter motor. If one of the windings is broken it will do that, with a bit of a bump or nudge (slamming the door) it can get over to touch the next winding. If that is what it is then its a new starter motor you need. Only other thing I have seen do that is a rusty connection at the battery, ground at the block, or either connection on the solenoid. It can be tested by using a volt meter at the motor terminal of the solenoid, if it has full voltage when it just klicks then its the motor.
Old 04-08-2012, 12:18 AM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Replace the starter. Easy to do, but you will need the correct tools.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Super Strange starting problem-Help. j.patelia S-10 4 12-04-2004 04:19 PM
strange starting problem Deniz Caravan | Voyager 4 09-08-2004 07:30 PM
strange starting problem oldcountry C/K 4 04-20-2004 03:49 PM
Strange starting problem eeyore Maintenance 6 04-30-2002 08:39 AM
