Old 04-10-2004, 11:04 AM
oldcountry oldcountry is offline
strange starting problem
I'm having a problem with an 1989 chevy 4.3. It takes a long time to start when it's cold. It cranks for about 30 seconds. When it does start it runs fine, and when it warms up it won't start at all. You can crank it untill the battery goes dead. But it will start after it sits about 10 minutes. the funny thing is, if you get it rolling and pop the clutch, it fires right up. I'm stumped. Any ideas would really be appreciated.
Old 04-10-2004, 01:06 PM
michelq michelq is offline
Re: strange starting problem
i would try a fuel pump relay then go from there
Old 04-13-2004, 12:03 AM
daemonhat daemonhat is offline
overheated starter maybe?
Old 04-18-2004, 11:20 AM
97chevyman's Avatar
97chevyman 97chevyman is offline
sounds like it is not turning fast enough. If you can pop the clutch and get it to start. Try a new battery and connections on the starter.
Old 04-20-2004, 03:49 PM
toivo toivo is offline
unplug your coolant sensor next to the thermostat and see if it starts right up. it will make it hard starting. also if ypur sparkplugs have too large of a gap it will fuss.
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Strange Starting Problem BlazerHater Blazer 11 12-26-2004 02:50 PM
Super Strange starting problem-Help. j.patelia S-10 4 12-04-2004 04:19 PM
strange starting problem Deniz Caravan | Voyager 4 09-08-2004 07:30 PM
Strange starting problem eeyore Maintenance 6 04-30-2002 08:39 AM
