| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Hi everybody,
Can anybody give me any ideas for reducing the fuel costs, considering there is no chance of the price of oil coming down! |
Re: How can I reduce my fuel costs?
Pretty much the only things that work are getting a smaller, more fuel efficient vehicle, reducing as much weight as possible in your current vehicle, keeping your vehicle in tune, keeping the tires properly inflated, and minimizing aggressive driving habits.
You're not likely to find a reliable tune that will improve mileage enough to offset the cost, and if your car has been properly maintained, additives won't likely make a quantifiable improvement either. -Rod |
I second that. Aside from driving habits, there isn't much you can do aside from buying a more efficient vehicle, though there are people who over-inflate the tires and put fender skirts on to lower roiling/air resistance. Not sure how much that changes things.
Driving habits..... slow down a little.
If you double your speed, wind resistance increases by a factor of 8 (if I remember correctly), so a modest decrease in highway speed decreases fuel consumption dramatically. |
Tune up the engine & maintain it regularly. In this way, the engine runs more efficiently and becomes more dependable. Remove unnecessary weight from the vehicle and inflate tires to the correct pressure. I am pretty much sure that by following this advice you will get the desired solution.
People often laugh, but tape a spacer under the accelerator so you can only get about 3/4 throttle. I had a pickup that I attached a valve spring under the accelerator so full throttle was still possible, but the spring acted as a limiter.
tune-up tire pressure driving habits
Dragging people kicking and screaming into the enlightenment. |
Do a Google ''EPA gas mileage <make> <year> <model>''
If below EPA - Your going to need a good tune up 1st. Include a new Air/fuel filters, clean MAF sensor, and a new upstream HO2 sensor. Last edited by danielsatur; 05-23-2011 at 09:41 AM. |
Also using cruise control saves up to 14% on gas and avoiding excessive idling can save up to 19% on fuel.
That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved. For with the heart man believeth unto righteousness; and with the mouth confession is made unto salvation. Romans 10:9-10 |
Hi All,
I found a website that has a fuel additive that increases you mileage. I get on average about 325 miles to the tank, and after using it two times I've managed to go an extra 30 on the first tank, and I've gone and extra 44 miles this time. I am now on my third tank and we'll see how I do. I'll post back in a week or two and let you know if the results stay the same. The other thing I noticed, was I have 110,000 miles, once in while it pings, and since I have been using this, I haven't heard any pings. I'll keep you informed. Here is the website I got the additive from [link removed] David Last edited by curtis73; 05-25-2011 at 10:10 AM. |
Start riding a bicycle.. Just my
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
A cold Air intake can do the same thing, it's easier to breathe air!
You can replace a paper air filter with a sham wow and get the same results. |
... IF the original air cleaner was a restriction, then yes. Some CAIs don't improve anything except the seller's wallet.
[quote=AndrewChan84;6901374]I have a product that can improve 1.5 to 2 mpg, as well as optimizing the engine, and AT smoothness
[links removed] I have gone to the links that were removed, it look's like it might beable to keep 12volts dc on the system during a battery replacement so data isn't being lost on Ecu/Pcu, and control modules. The Sham wow works as a good cabin filter too! |
