Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 05-19-2011, 06:28 PM
jebwhyme jebwhyme is offline
burning icm's, 91 2.3
Truck was running like it had a bad miss. Codes for egr, replaced, crank position sensor, placed, icm replaced, fuel pump replaced, exhaust side coil pack replaced, o2 sensor replaced. All codes are clear, but when driving at high speed, it cuts out, and even dies. If I unplug exhaust side coil pack, it fixes the problem. The only out of spec I see is alternator pushing about 15v, my question is this, could higher than ideal voltage from alternator be fouling the icm?? Or could the pcm be bad also?
2,3 Miller Cycle is burning oil, help please! johnvjason Millenia/Xedos 9 0 06-01-2007 06:25 PM
differences between 2.2/2.3/3.0 ruffio1842 CL | Inspire | Saber | TL 1 01-12-2006 03:37 PM
Engine Swap From 2.3 SOHC to 2.3 DOHC HO Carly_433 Achieva 8 09-11-2005 11:35 PM
2.3 i-4 to 3.2 v6 1984 zexel42015 Performance 3 03-19-2005 11:32 AM
3.1...2.2...3.1...2.2...with enough "persuasion" ne thing works aviator18 Cavalier 0 06-07-2004 11:21 PM
