Old 05-19-2011, 04:44 PM
butchsterling butchsterling is offline
1996 S-10 not getting fuel
I have a 1996 S-10. It was running fine till I stopped to let a tractor turn into a field. When I went to go it hessitated and then died. If I pour gas into throttle body it starts and runs for a few seconds.When it first happened I turned the key and heard fuel pump run but still didn't start. Now if I turn key I hear nothing. I had a 1991 s-10 that seemed to do the same thing and it ended up being a module in the distributor.Does a 1996 have the same module or does anyone have any other ideas?
Old 05-19-2011, 06:38 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 1996 S-10 not getting fuel
It sounds like you may need a fuel pump. You need to check your fuel pressure with a fuel pressure gauge. You'll see a valve with a black cap that looks like a large tire valve toward the back of the engine of the driver's side... connect the pressure gauge to that valve and check pressure with the key on, engine off. The pump should run for about 2 seconds when you turn the key on, during this time the pressure should be 60+ psi.
Old 05-20-2011, 05:16 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As Blazee said check for fuel pressure.
But before throwing parts at it dom some proper testing.
Giving it squirt of gas or carb cleaner and startb and run a few seconds indicates a fuel delivery problem.
Could be bad fuel pump or relay or fuse or wiring problem.
If you have good spark that rules out dist. module or ing problem.
Next step is to jumper fuel pump with a 20 amp jumper and see if fuel pump runs and pumps prober pressure.
If not check fuel pump and wiring neg and positive.
If pump has power to it and good ground and no runn or low pressure then your pump is bad.
Key on 2 second prime up the fuel pump relay should turn on fuel pump for prime up.
Make sure the relay has 12 volt power to it and is turning on for prime up or engine cranking.
If a after market remote start or anti theft stuff make sure it is not shuttting down fuel pump.
Run these test and post back results.
If pump is bad always use a delphi fuel pump replacement.
MT
Old 05-20-2011, 11:32 AM
Checked pump pressure it was 50# while running.I tapped on fuel tank and it sounded hollow so I dumped more gas in and it started up.50 # of pressure at idle. Now it doesn't want to start again and if I do get it started it doesn't sound good and I have to feather the gas pedal to keep it running. Gonna try changing fuel filter and see if that helps. I do hear the pump run so it is getting power.
Old 05-20-2011, 12:06 PM
blazee's Avatar
Problem?
You have to check the pressure without the engine running...
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 07:09 PM
please help no start fuel injectors not getting fuel pjftmd107 Problem Diagnosis 6 12-07-2009 05:23 PM
92 accord #1 cylinder not getting fuel martina75 Accord/TSX/Accord Hybrid 15 08-19-2005 07:40 AM
1985 not getting fuel wesw02 Fiero 4 06-22-2004 04:18 PM
