Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 06-19-2004, 11:01 PM
wesw02 wesw02 is offline
Send a message via AIM to wesw02
1985 not getting fuel
my friend has a 1985 fiero and the engine won't start, the spark plugs are sparkign but it won't start, he thinks its not getting fuel and he has already installed a new fuel pump, spark plugs, spark plug cables, carboator, oil filter, and changed the oil, still just sparks won't start, any ideas ?????
Old 06-20-2004, 10:54 AM
RedFiero RedFiero is offline
Re: 1985 not getting fuel
hows about the fuel filter, seems like thats the only thing you've not mentioned. Is the pump actually running....and is there gas in the tank. May sound like I'm being an idiot, but more than once cars have run out of gas and the gauge has shown a reading.
"When I Die I Want To Go Peacefully....Not Screaming Like My Grandfathers Passengers"
Old 06-22-2004, 12:41 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Mine runs out at an 1/8 of a tank Sometimes the gauge sending units wear out and do that. You didn't mention if it's a 4 or a 6, but either way a fuel pressure regulator could do it... busted wire to the injector on a 4 could, too. And as already said, crap in the fuel filter and or lines will do it as well.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 06-22-2004, 04:33 PM
nope guys he replaced the fuel filter and put gas in the tank, he said that when he upplugged the fuel line (don't know from where) and tried starting it no fuel came out
Old 06-22-2004, 05:18 PM
Does the fuel pump run when the key is turned to on? If so the supply line is clogged. If not, there's an obvious wiring problem or maybe a defective fuel pump, it happens with new parts once and awile.
Wanted to buy:
