Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-17-2011, 12:38 AM
Captain Ahab Captain Ahab is offline
Crank pulley install tips
Hello all I just recently replaced the timing belt on my wife's '98 Neon. I'm installing the crank pulley. My issue is that the crank pulley is about 1/4 in. off alignment with the water pump pulley. I am having a bear of a time trying to get the pulley to slide on the last 1/4 in. any help in this area would be greatly appreciated.
Thank you in advance for any input.
Old 05-17-2011, 06:53 AM
denisond3 denisond3 is offline
Re: Crank pulley install tips
Assuming you have that crank sprocket on the right way - it can be put on backwards I think - then I would think it is either a burr on the crank surface or on the inside of the pulley, or that the woodruff key isnt seated properly. I recall it has to be really 'flat' down into the groove so as not to interfere with the groove in the sprocket sliding over it. You might need to take a file and remove any burrs or gouges on the sides of the woodruff key.
I call the crank 'pulley' a sprocket, since it has 'teeth' on it.
Old 05-17-2011, 09:48 AM
Whoops, sorry I meant drive belt pulley. I didn't take the crank sprocket off. Sorry for lack of clarity.
Old 05-17-2011, 08:12 PM
As far as I know, the only way the belt pulley (also the vibration damper) is going to go that last short distance is when the bolt holding it onto the end of the crankshaft is torqued up. This also implies holding the engine from turning; using the teeth on the starter ring usually. Again, the woodruff key needs to be aligned nicely with the pulleys that are going to slide over it.
I may start taking the engine out of our family's 97 Neon, since its smoking a little blue, and is misfiring due to damage to the back part of the engine wiring harness.
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
WTB: Mass Area Crank Pulley & Power Steering Adjuster Pulley invictus_92 Probe 0 12-23-2004 10:24 AM
crank pulley removal RickDaTuner Engineering/ Technical 6 03-26-2002 08:22 AM
Crank Pulley Prep soul180 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-11-2002 11:26 AM
Lightened Crank Pulley from UDP Austin Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 07-12-2001 04:57 PM
