Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 05-16-2011, 02:55 PM
lilwhitelude lilwhitelude is offline
Send a message via AIM to lilwhitelude
c6 transmission issue
I have a 86 bronco full size 351w with a c6 in it. My transmission front pump bushing came out and dropped all my fluid and caused a pretty big problem. I replaced the front pump and completely rebuilt the transmission. This is my first automatic to rebuild so it was a little venture. After building it,it works great, except it shifts way too smooth. I checked the modulator valve and it holds vacuum well. Any suggestions on what would cause my transmission to shift so smooth that I can't really feel it shift? Thanks for any reply.
DM112375
Old 05-16-2011, 08:20 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: c6 transmission issue
2 things come to mind.
First of all, the C6 is supposed to shift like this, in many applications. Very soft smooth shifts was "programmed" in to about a bazillion C6 tranmissions, particularly when used in large Ford, Mercury and Lincoln cars. If you changed the valve body or springs, you may have just "programmed"it for such soft shifts.
My other guesses are:
If the trans really does feel wrong, there may be something stuck, leaking or improperly assembled in the valve body, and/or the line pressure may be too low. For example, somewhere in the valve body is a tiny check ball held in place with a tiny spring that looks like it came from a ball-point pen. If these two components are installed in reverse order, you get very mushy 1-2 shifts, and a slipping second gear.
Finally, you might have an improperly-adjusted second-gear band.
Old 05-18-2011, 12:28 AM
When I rebuilt the transmission. I didn't do anything but clean out the valve body. I was careful to take pictures and visually inspect and clean ever part. The check balls are about 1/4 inch in diameter and seating in the original location. I guess I should have replaced the seals on the pistons in the valvebody. THis transmission always shifted firm before the bad stuff happen. Ive been looking for an excuse to put in a shift kit. I guess if the valve body comes back off, it's gettting one. Before I pull the pan again, Id like to know if is possible that a weak spring in the servo could cause smooth shifts. Thanks for replying.
Dm112375
98 Transmission shifting issue zawillia Windstar 4 05-02-2010 02:21 PM
94 prizm transmission issues theginchico Engineering/ Technical 3 04-12-2010 07:17 PM
1989 grand marquis transmission issues Thepinkmommy Grand Marquis 2 04-03-2010 10:26 PM
transmission issues. 91 buick regal 3.8 bac512 Regal 0 04-25-2009 11:58 AM
Transmission Issues hoowahman Park Avenue 1 11-19-2002 03:30 PM
