Old 05-15-2011, 10:15 PM
AlphaCrow AlphaCrow is offline
Metal rattle at warm-up
(2000 Blazer, 4D, 2WD, 6cyl, 150k miles) Rattles when started. Turning off A/C during warm-up makes the sound go away or at least reduces it to a muted rattle. During idle, goes away quicker if driving. Seems to be coming from the front of the engine (I initially thought the hood brace was loose). No engine hesitation or otherwise. Do you think it's the tensioner assembly? It's been going on for a long time, and still passing emissions test, so I assume catalytic is still kicking.
Old 05-16-2011, 04:35 AM
pkrieter pkrieter is offline
Re: Metal rattle at warm-up
Check the belt tensioner and idler for loose bearings, and check the exhaust for heat shields that are corroded. Also might be a loose engine mount bolts.
Old 05-16-2011, 04:26 PM
bozr's Avatar
bozr bozr is offline
Check the alternator bracket mount for loose bolts. Had that rattle on my 2000 also.
I love the smell of Stoichiometric in the morning.
Old 05-18-2011, 05:46 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Simple test for a bad Cat, Bang on it with a rubber mallet and see if it rattles.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 05-21-2011, 02:45 PM
Good idea! Lemme give it a go
Old 05-21-2011, 02:56 PM
Ok, question: The bolts look good, but the tensioner pulley fluctuates when engine is running. Should it hold strong and not move during operation, or should it bounce slightly like it is?
Old 05-21-2011, 05:44 PM
Banged on catalytic, no noise from it, though the whole exhaust pipe vibrated and a slight rattle against the frame.
Old 05-21-2011, 09:48 PM
It will move around a bit but not too much.
Old 05-21-2011, 09:50 PM
There should be at least an inch of clearance between the exhaust and any part of the frame.
Old 05-29-2011, 05:13 PM
Ok, got the new tensioner in the mail. Installed, rattle SEEMS to be gone after a few days. I did here it once, briefly, but very muted compared to before. Otherwise, it's silent and appears fixed. Thanks for the help guys.
To warm up the car, or not to warm up the car? ice745 Engineering/ Technical 15 04-14-2007 03:23 PM
1994 SL-2 Cold Rattle/Warm no rattle slight hesitation acidburn_335 SC/SL/SW 6 09-27-2004 10:16 PM
metallic rattle??? bilalboyz Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 08-13-2004 04:04 PM
metallic rattling noise in 2001 silverado swampboy C/K 2 04-20-2004 09:35 AM
2001 740iL metallic rattle on engine start jtietz 7 Series 1 11-08-2003 07:16 PM
