Old 05-15-2011, 03:20 PM
lstpaul lstpaul is offline
S-10 wont start
My chev s-10 has been slow to start, now wont start at all, Cranks well wont start. Fuel pump and filter are good. replaced the cam shaft pressure sensor and the crank shaft pressure sensor. no luck, and ideas?
Old 05-15-2011, 03:33 PM
brcidd's Avatar
brcidd brcidd is offline
Re: S-10 wont start
An engine needs 4 things to start and run,
Fuel- is fuel pressure up to spec- measure it with guage
Air- is throttle bypass, IAC open
Spark- do you have nice hot blue spark- tested with spark tester?
Compression- sure engine doesn't turn too easily? as in timing chain failure?
Year and engine size would be nice-my crystal ball says it is a 2.2L- with a sloppy timing chain-- but I've guessed wrong before.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-15-2011, 05:00 PM
j cAT j cAT is offline
Re: S-10 wont start
it is good to give vehicle details....engine/yr/mileage etc...
squirt an ounce of fuel in the intake manifold see if it starts..take a plug wire off get old plug cranking engine blue spark ?
why is fuel pump/ filter good ? how did you determine this ? what was the pressures...also did the fuel pressure hold on ignition off cycle...
other items like a plugged exhaust can create a poor/no start..
the engine is a pump if it cannot exhaust it cannot suck in air/fuel...
need more vehicle info to see what other stuff or testing required
get DTC failure codes ..
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
95' S-10 Wont Start! PLease help me blade34609 S-10 2 08-16-2004 01:23 AM
Newly aquired 94 4x4 s-10 wont start... 2ROTORRACING S-10 4 07-03-2004 04:14 PM
1984 S-10 Wont start!! Help!! cholmes S-10 2 08-21-2003 02:33 AM
