Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 05-14-2011, 05:29 PM
jtmarten jtmarten is offline
Rear upper bushing replacement
Just finished replacing the entire front steering, all 4 struts/shocks. When replacing the pass side rear, found the upper knuckle/arm bushing is shot. I've seen poly bushings available so I won't have to buy the entire assy, but do the bushings need to be pressed in/out, or can I do them without a press?
Thanks!
Old 05-15-2011, 11:31 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Rear upper bushing replacement
I just replaced the upper knuckle bushings on my car last week. I bought just those single poly urethane bushings on ebay for around $40 for both. The factory ones are pressed, but you dont need a press to get them out. I took a torch and melted the rubber out of the bushing. There is a metal sleeve between the rubber and the knuckle that you have to remove. I took a sawzall and cut a few slits in the sleeve, and it popped right out. You simply grease up the poly bushings and they slide right in.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-15-2011, 01:20 PM
Sweet, I was hoping for an easy fix! Hopefully I'll have the bushings by mid-week.
2002 Rear Knuckle Bushing Replacement jrozanc Rendezvous 4 08-23-2010 08:28 AM
CRX DX Rear Bushing replacement rusted '88 - '91 Civic | CRX | Wagon | Shuttlee 10 08-19-2009 11:08 PM
rear door pin/bushing replacement M.S.Services Suburban 3 03-20-2007 09:13 PM
Anyone replaced rear door bushings? 2gmSees Yukon 0 03-01-2004 03:45 AM
Tie Rod upper bushing replacment lounjacked Grand AM 0 02-01-2004 12:34 PM
