Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-14-2011, 12:07 PM
nuckolsk's Avatar
nuckolsk nuckolsk is offline
NUCKOLS
ac pressure hi and low 2000 ls v6
does anyone have the hi and low side pressures at varing ambeint temps ?
Old 05-14-2011, 02:28 PM
joegr joegr is offline
Re: ac pressure hi and low 2000 ls v6
This is for a 2006 V8, but it should be about the same for a 2000 V6.
http://deneau.info/ls/s6x~us~en~file...tm~gen~ref.htm
The Following User Says Thank You to joegr For This Useful Post:
nuckolsk (05-14-2011)
Old 05-14-2011, 02:39 PM
nuckolsk's Avatar
NUCKOLS
thanks, that should help later. new problem. i know i saw the clutch turning at the start of all this "fun", have charge in system low side 42, but clutch will not engage. checked #1 - 10amp fuse and clutch relay by swaping with the washer pump relay. don't know what else to check?
Old 05-14-2011, 02:41 PM
nuckolsk's Avatar
NUCKOLS
maybe a high side pressure switch?
Low Coolant Light and Low Oil Pressure Light is on were are they located? dizzle1 Intrigue 12 06-04-2009 01:35 PM
Difference between a high pressure and low... ned032002 Bolt on Parts 3 10-27-2007 12:09 PM
Which is the High pressure and low pressure line for A/C? mistervelasco 3 Series 1 08-05-2005 09:03 PM
