Old 05-13-2011, 09:02 PM
vohelpe vohelpe is offline
Aluminum wire size???
Hi
i just started in scratchbuilding aluminum parts and i need to know what size of alu. wire can i use for coil overs of 1/24 and 1/25 scale???
Thanks
Old 05-14-2011, 07:58 AM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
Re: Aluminum wire size???
I would just use what looks right, and what you are happy with .
gpz900ra7.
MY 1:1 toy
Old 05-14-2011, 03:17 PM
racer93's Avatar
racer93 racer93 is offline
Exactly. I'd get a bunch of different diameters and experiment. That's what I do. It comes in handy later, anyway...
Old 05-14-2011, 08:45 PM
thanks
ill do that i get different sizes and try with the best at the moment
Old 05-15-2011, 11:24 AM
lotus123's Avatar
lotus123 lotus123 is offline
There are a few tools that I conside to be essential, such as an airbrush (and in my case) an Optivisor.
However, one that I find indispensable and that I keep close to hand is my digital vernier caliper. It's absolutely essential for figuring out the right size for anything.
If you consider that a typical coil-over spring is about the thickness of your small finger then it's simple enough to measure that, divide by 24 and there you have your answer. Even better, setting the caliper to that scale size then helps you to find the right material very quickly.
Old 05-16-2011, 06:02 PM
Thanks for all the replies, i will consider all the options. By the way i already got a digital caliper and airbrush system. Right know im starting to know how to turning parts in a new lathe that i bought a month ago. So if any of you got ideas or advices they will be welcome too.
Thanks again
What wire size should I get? DeadBlade89 Car Audio 2 06-02-2007 10:38 PM
Wiring sizes? tigeraid Car Modeling 17 12-11-2006 08:03 PM
wire sizes Bain Car Audio 6 11-21-2006 06:01 PM
Wire size help sutan Car Modeling 2 03-18-2006 09:20 AM
Need suggestions for braided hose and wire sizes..... Deejay27 Car Modeling 2 12-20-2003 11:11 AM
