Old 05-12-2011, 06:12 PM
Majortom84 Majortom84 is offline
99 Taurus SE - Chirping from driver's side
Hi,
While looking to see where the 'chirping' sound is coming from on my 99 Taurus SE (Vulcan), I noticed a disconnected cable, right behind the battery/under the air intake - (m/f three prong) - it looks as though this has been disconnected for some time - could this cause the 'chirp'
Sorry, this is probably a dumb question, but I don't want to mess around without checking first
Old 05-12-2011, 07:24 PM
inafogg inafogg is offline
Re: 99 Taurus SE - Chirping from driver's side
Originally Posted by Majortom84 View Post
Hi,
does the noise appear to be coming from the engine?may be the belt
as far as disconnected cable is it a heavy gauge like a battery cable?
or something smaller
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
Majortom84 (05-12-2011)
Old 05-12-2011, 07:33 PM
Thanks for the reply,
I'm pretty certain that it's coming from the driver's side, although I've heard there's a method of 'spraying soap' on the belt's to find out (?).
The wire is wrapped in metal, (runs from the driver's side headlamp to the firewall - lights work fine though) not as thick as battery cables - each end has a plastic connector, three prong - not sure if it's supposed to be like that, from the dust on it, looks like it's always been like that.
Old 05-12-2011, 07:50 PM
tempfixit tempfixit is offline
Chirping on the drivers side could be the Camshaft Sensor
Use a hose or screwdriver and place it on the sensor while running and listen if it is chirping.
The Following User Says Thank You to tempfixit For This Useful Post:
Old 05-12-2011, 09:21 PM
Thanks,
It looks like that's the cause... from what I've read, the parts are inexpensive, looks like it could be easy enough to replace (?).
Old 05-13-2011, 12:18 AM
Thanks,
Here is a video on replace sensor and syncronizer
http://realfixesrealfast.com/realfix...am_Sensor.html
Driver's side window - 06 Taurus Yahwehdo Taurus | Taurus Wagon 4 12-17-2010 06:30 PM
Squeaky noise coming from driver's side?? Speedi Colorado 18 05-13-2006 06:07 PM
chewing sound from driver's side when steering to left ONLY. dushanya Neon | Plymouth Neon 7 03-13-2006 12:36 PM
Thumping sound coming from driver's side wheel dgreggs Cavalier 1 08-03-2005 08:57 AM
Removing salt stains from driver's side door chkm8k2 Camaro Discussions 20 08-16-2004 03:47 AM
