Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-10-2011, 06:04 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Odd Problem
My girlfriend has a 97 camry le V6. the car has a 170k on it and runs fine with only needing a new starter in its life, my problem is thus: In order for the car to turn over and run the key can not be removed from the ignition. We leave the key in the ignition and have to leave the car unlocked because if we take the key out, it can take upto an hour of constant turning before it turns over. The key is genuine toyota and does not appear to be worn down. And like I said if we leave it in the ignition once the car fires up, it starts every time. any ideas?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-10-2011, 06:48 PM
FishFind FishFind is offline
One Hot Shot
Re: Odd Problem
Get a new ignition or check for a loose wire on that one?
Old 05-30-2011, 09:48 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Odd Problem
Sounds like your ignition switch is going bad. Over time the contacts can become worn and oxidized. I believe this can be replaced without having to change the locks/keys.
Another possibility is that your neutral start switch is going bad. This is to prevent the car from being started while in gear.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-15-2011, 08:56 PM
crxlvr's Avatar
Re: Odd Problem
i assumed ignition switch too, but after looking into what that entails on her car, we will just be leaving the key in the ignition lol. The whole drivers side area damn near has to be replaced.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-21-2011, 08:57 PM
jdmccright's Avatar
The RustBuster
Re: Odd Problem
Check the Park/neutral switch as well. If the car thinks it isn't in park or neutral because the switch is bad or the shift lever is sticking, then it won't start.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
2000 radio odd problem craigie_32571 '97 - '03 4 03-20-2004 09:19 PM
Please help ASAP... very odd problem w/'98 Civic!!!! primalauto Engineering/ Technical 1 10-25-2003 04:07 AM
odd problem IXLR8TL3.2 Discovery | LR3 | LR4 3 03-06-2003 11:57 PM
An odd problem, need some help. YellowMaranello Engineering/ Technical 7 08-07-2002 11:05 PM
odd problem in the snow Brian P General 5 02-15-2002 09:44 PM
