Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-10-2011, 01:57 PM
trs's Avatar
trs trs is offline
spark plugs
hello i have a 2001 montana 3.4l. i was wondering how do you change the spark plugs in the back, there is 3 in the front just don't know how to get the back ones.
thanks
tom
Old 05-10-2011, 03:29 PM
scherp scherp is offline
Re: spark plugs
You need to roll the engine forward by removing the air intake from the filter to the throttle body and removing the top two engine mounts. Use a ratchet tie down you pull the engine forward.
Then from the bottom you follow the exhaust pipe up to the spark plugs. Use a flex ratchet. The hard part is getting the boots off the plugs. I had to cut them off. Good luck.
Old 05-11-2011, 12:33 PM
rkvons's Avatar
rkvons rkvons is offline
Re: spark plugs
You don't want to do both of these, just get the front of the vehicle on jack stands and get them from underneath. Alot of it will be by feel, because you can't always see what you are doing. It's not really that bad.
spark plugs 1999windstar LaCrosse/Allure 7 05-02-2011 10:08 PM
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
