Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-10-2011, 11:38 AM
jerry101 jerry101 is offline
Smile leak
i have a 2003 chevy cavalier,the problem i have is that it has a leak in the windsield washer supply hose , how do i fix this problem ? it has one hole in the hose near the battery ,and one underneath the battery support.
Old 05-10-2011, 01:39 PM
maxwedge maxwedge is offline
A990 racer
Re: leak
Um, replace it?
Old 05-10-2011, 05:42 PM
Re: leak
no, really. do you have to look that up in some book
Old 05-10-2011, 06:34 PM
j cAT j cAT is offline
Re: leak
hoses in time leak..could be from chaffing ...cut out a section bring to the auto parts store and get new piece of hose/tubing..
your question does not appear to be that complicated ..why do you ask about this ?
Old 05-10-2011, 07:00 PM
Smile Re: leak
the problem is i can disconnect the hose on the underside of hood ,but can't gwet at the other end ( under the battery support ) too much stuff in the way
Old 05-11-2011, 07:55 AM
Re: leak
remove components to get at the tank connection then fasten new line to old line and pull until it is at the firewall connection..
this may not be possible with fasteners used to secure these lines to the car body so re routing the new line may be used ...
Old 05-11-2011, 06:18 PM
A990 racer
Exclamation Re: leak
As a forum moderator I would suggest that in the future to clarify your posts, such as why you question the hose issue as you never asked or stated that it was difficult to access, did you?
cam seal leaks and leaks and leaks... carpenter_jai Metro 13 05-05-2009 02:27 AM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 11:10 AM
93 Heater core leak/firewall leak Ritthjp Cavalier 14 10-08-2004 02:39 PM
1996 GA GT - Leaks, leaks, leaks VICGT Grand AM 0 05-20-2004 05:24 PM
