Old 05-09-2011, 09:07 PM
wagslick wagslick is offline
Grease in the wheel well
I have a 2007 Silverado z71 and it's swell. Just bought it a couple months ago. Has 95k on it. After coming home from work I noticed a little bit of grease in the wheel well as well as a tad of grease on the body of the truck. I'm not 100% it's mine but I dont know where it may have come from. Took the wheel off and looked at the brakes, and grease fittings. There aren't any signs of splatter there or on the inside of the wheel. Just the wheel well. Any idea what my have caused this?
Something that may possibly be related is that the brakes in this particular wheel (front passenger) have been crazy squeaky, but they only squeak when i'm NOT breaking. If I tap the brakes, the squeak goes away. Sounds like a clip is loose but I checked things out and cant find anything loose. Any ideas? I posted the brake squeakyness in another thread.
Old 05-10-2011, 01:03 AM
KaIIen KaIIen is offline
Re: Grease in the wheel well
Xenia eh? Hi neighbor. Well, the squeak behavior you mention, my first thought would be worn brake pads. I would definitely look closely at the pads and consider a quick swap on those. While you're in there, wipe off any excess grease and keep an eye out for any new grease. Looking at your pics, I am pretty certain that you drove through something because it's slung up the fender. There's no real way that if it came from the inside side of the tire like from a joint, that it could get slung up the outside like that...but I would monitor that just in case..
Old 05-10-2011, 09:17 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you had driven over a blob of grease it would have penetrated into the tire tread and you should see some residue embedded in there. From the pic of the underside, it's almost as if it was squirted onto the underside, like you ran over a packet of grease and it got squeezed out of a tube or something.
It looks to be alot of grease, but the only other possibility is that one of your ball joint rubbers split and squirted grease...trouble is that it would work its way around the inside of the wheel, not the outside like you show.
I'm going with theory #1...drive over anything recently?
As for the squeaking, also check that the inside and outside pads are wearing equally and evenly. If the caliper isn't sliding free, it can wear one of the pads too fast. Remove the caliper from the wheel bracket and check/replace the slide pins and use a good amount of grease.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-10-2011, 11:05 AM
kahjdh's Avatar
kahjdh kahjdh is offline
Representing Akron here..
I would also check the cv boots. If there is just a pin hole in the boot the grease will fling out. The heat from the bearings thins it out and the centrifical force flings it all over the wheel well.
On the brakes just pop the caliper off and make sure the anti-rattle clips are not hitting the rotor as well as the squeelers on the pads. I always put a line of permatex ultra black hi temp silicone on the backs of the pads and rip off the little plate that clips on to the back of the pads. Let us know what you find.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 05-10-2011, 10:27 PM
4x4junkie 4x4junkie is offline
Occasionally mistaken a wheel bearing can sound similar to brakes squeeking.
Just a possibility. These trucks have a sealed wheel bearing inside so this is a highly unlikely thought for it to be dispersing grease, however if the temperatures are high enough in the wheel bearing due to a prior failure on the vehicle that is unknown, its possible the grease can be liquifying and traveling across the center hub of the wheel and being slung outward....the loss of grease in the wheel bearing cound be casuing your noise......VERY UNLIKELY CIRCUMSTANCE! (million to one odds) but if the wheel is being removed to check brakes note any location of grease found becasue it may help determine the answer. Its a fact that cv joints sling grease when the boot is bad, has a hole, torn or if the clamp is missing or broken.
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
Old 05-14-2011, 09:07 PM
gremlin96 gremlin96 is offline
welcome to the open road. your grease is from a semi. chances are you got fling off from one going down the road. it happens all the time. i have some on my truck about once or twice a month.
07' silverado Metal on Metal intermitent Screeching from Right front wheel well rescue24 Silverado 5 05-20-2010 09:44 AM
Well I found the wheel speed sensor... it's broken and w/o trigger. Pics of yours? Cobra4B GTRA / GTWS / GTS 6 01-08-2008 04:45 PM
What are the Cogs in the wheel well? Broadswords Mark VIII 4 01-25-2006 12:50 PM
Any pics without the wheel well on? Shaguar47 Insight 7 10-03-2004 03:17 AM
How to tuck slicks inside the wheel wells? AstroRide44 Car Modeling 2 04-20-2004 05:46 PM
Tags
brakes , grease , wheel
