Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-09-2011, 07:15 PM
vertigo14k vertigo14k is offline
Question Gen 4 - 2000 Camry Engine tilted
I recently replaced all four motor mounts, and also wanna note that I've replaced the dog bone mount 2 time before. The engine is tilted like 1 inch to the dog bone side, and has been vibrating a little too much. I wanna know why the engine tilted to the side, and what else do I need to replace.
Old 05-14-2011, 09:20 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: Gen 4 - 2000 Camry Engine tilted
Review your receipts. Double check the part numbers. Make sure they're right for your engine (not 4 cyl. when you need 6 for example). The engine and transmission mounts are the only things positioning the engine. Trans. mount is usually OK. Don't really follow "tilted to the dog bone side" -- usually fluid filled front or rear mount goes and engine tilts to the front or back. If you're sure you got all the right parts, and you're sure they're all installed correctly - that is fully seated - then one of your parts is bad -- probably the low side. It is unusual but not impossible that a new part is bad. Have had it happen with dealer supplied front strut and timing belt. The strut made noises right out of the box - dealer installed - checked everything twice until finally had to replace the new part. Timing belt was just too long. Hit the cover even at full adjustment until I replaced it with one from AutoZone and that one was fine.
Camry 2000 Check Engine Light Code HELP>>>>>> minh100 Camry/Camry Hybrid/Vista 16 05-16-2012 11:47 AM
98 Camry engine replacement. posiman Camry/Camry Hybrid/Vista 6 02-01-2010 01:00 AM
2000 gt idle control/revving by itself wantaGTO Grand AM 2 11-19-2009 12:01 AM
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
2000 Camry Check engine Light w/P0420 nbaptist Camry/Camry Hybrid/Vista 5 03-16-2006 04:24 AM
