Old 05-06-2011, 08:35 AM
Fecklar Fecklar is offline
2000 Chevy Astro trouble code P0420 failed emissions test
Hello everyone,
I have a 2000 Astro van (cargo) that has a trouble code of P0420. It failed the emissions test badly. It passed on all curb idle readings but failed on ASM2525. It's almost due for a tune up so I will do that because it needs one either way. I found some info on P0420 and found the following:
A code P0420 may mean that one or more of the following has happened:
An oxygen sensor is not reading (functioning) properly
The engine coolant temperature sensor is not working properly
Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
Retarded spark timing
The oxygen sensors in front and behind the converter are reporting too similar of readings
I just don't know where else to start, I will check the exhaust manifold for cracks. Any sound advice would be appreciated. O2 sensors are old as well.
This is a very high mileage vehicle with 260,000 miles on it. It does not burn oil or anything and runs well.
Thanks in advance.
Steve
HC ppm Limit 50 Reading 86
CO% Limit 0.28 Reading 0.61
NO ppm Limit 548 Reading 1037 at 1305 RP
M
Old 05-08-2011, 11:02 AM
Blue Bowtie's Avatar
Registered Offender
Re: 2000 Chevy Astro trouble code P0420 failed emissions test
Start by verifying a good ignition system. Even though there may be no misfire codes, ignition could be marginal. The acceptable idle readings and poor loaded readings might indicate a weak ignition. Worn, wide spark gaps can suffer spark blow out and/or poor flame propagation and resultant poor combustion.
Verify the exhaust system, mainly to assure there are no air leaks. Include the EGR in that inspection.
Poor compression and/or leaky valves can cause generally poor combustion and the higher readings.
Of course, a clean inlet air filter is important. Make sure the MAF inlet screen is not contaminated with debris or heavy accumulations of dirt. This can skew the MAF reading and cause a leaner condition (high NOx readings).
Make sure the EGR is functioning.
Test the main OČ sensor to see that it can make a minimum of 0.95V with a hot bench test (propane flame). Perform the same test of the rear OČ. A weak front sensor can skew the mixture rich and result in higher HC and CO readings.
Old 05-10-2011, 07:50 AM
Well, I started off by changing the spark plugs, cap, rotor, wires, PCV, and air filter. I used AC Delco parts other then the air filter (Wix). The plugs did not look too bad. I will carry on with the advice you have given, and post the progress and results. Thank You.
Old 05-19-2011, 03:34 PM
I did not retest the vehicle until there was further diagnosis because I felt it would not pass after performing just the tune-up. I ended up inspecting the O2 readings pre and post cat, and the readings were the same. I put on an aftermarket catalytic converter, and it passed with flying colors.
Thanks
Steve
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
B16A Code 16 Failed Emissions Test Mojoe Let's get Technical! 3 05-07-2004 06:39 AM
1993 Astro 240,000 miles - Failed Emission NOx test WGO M Bodies 1 11-26-2003 06:14 PM
